587,426 active members*
4,355 visitors online*
Page 13 of 13 3111213
Results 241 to 254 of 254
  1. #241
    Jun 2006
    475
    Re: Another Banana Bender's Build !!!
    That ducting really fits good in there. What a great idea to use aircon duct. Ready made corners and bends. Good one Russ.
    Chich
    Sent from my GT-I9505 using Tapatalk
  2. #242
    May 2006
    2420
    Not to mention extremely cheap, haha!
  3. #243
    May 2006
    2420
    One added bonus is there is plenty of room for other things, in this case some terminals to terminate the servo connections and limit/homing switches...have to say that is more good luck than planning.
    Russell
  4. #244
    May 2006
    2420
    Did some serious hours on the machine over the weekend, unfortunately it doesn't look particularly different so no photos.
    I did however manage to power up and run the X and Y axis, after doing a lot of the mechanical tidy ups that I have been ignoring.
    Had trouble with a servo drive, I had sprayed it with an old tin of contact cleaner after soldering it up, it must have gone off or something as it reacted with the soldermask of the PCB and made a mess. I thought it would be OK but it seems not so.
    Lucky I had another drive I was working on for my mill retrofit and swapped it over.
    The plan is to get the machine going without limits/home switches, then use it to mill a small circuit board to use the hall effect homing switches. Things will be a lot safer then.
    Also high on the list is to put mechanical stops on the Y and Z axis, as they could over travel and run linear bearings off the rail, not too keen on that.
    Still waiting on a belt for the Z axis and also need to connect the servo/encoder, need to get hold of some 3mm bolts 45mm long to mount the encoder enclosure onto the servo.
    Getting keen now, this thing looks like a beast doing two axis rapid moves from one end of the table to the other.
    Russell.
  5. #245
    May 2006
    2420
    Connected and tested the spindle drive this weekend, the VFD cable I have is a little short but will do for now, it won't be long enough for the Z cable chain at the moment, but I need to do a couple of small jobs with the machine soon. It can sit in mid air for a while.
    Put rubber stops on the upper and lower Z travel, I would hate for the axis to overtravel now and lose the ballscew balls and linear bearing balls, that would be a nightmare.
    Not much room to play with but they seem to work and I didn't lose too much travel. Had to chop the lower one so the spindle didn't collide with it, looks a bit funny but does the job.
    Russell.
  6. #246
    May 2006
    2420
    Last belt turned up, Z runs sweet, the servo brake holds the axis when the drive powers off, I was worried there would be too much weight for the brake to handle at power down, and I was also worried the servo wouldn't hold the weight of the spindle assembly, but it does so easily.
    Only getting 2.4m/min on the Z, but I have cranked the encoder settings to 1000 CPR, which is 4000 pulses/rev in quadrature, as it only has about 115mm of travel that high a resolution (0.0025mm/step) is all good.
    Setup the scaling tonight, so now all three axis are calibrated and running nicely.
    Next will be to mount the VFD, I have a small steel enclosure that I will mount at the back of the machine to house it. The motor cabling is now run through the machine, just need to run power to the VFD from the electronics enclosure via the estop contactor and I'm in business. Oh a spindle start signal might be a handy addition as well.
    Plan to mount the VFD tomorrow, and test, then its onto milling some circuit boards for the home switches. Going to use the hall effect ones as per the thread by Romanlini here on the zone, with simple modifications to suit my machine, his circuit switches to ground, but the breakout board I designed needs a positive 24volt signal, so I used a PC817 opto to provide this, with very few components and designed a simple board layout that will hopefully be able to be machined with a brand new untested machine...no pressure!!!
    If anybody is interested I can supply the DXF of this board, it is untested as yet, but should work, we will see.
    Cheers.
    Russell.
  7. #247
    May 2006
    2420
    Starting to run the machine a little, here is a quick video of it doing some drawing, I wanted something that would run for a while, I think this took about an hour but don't worry, only recorded the first couple of minutes...
    https://youtu.be/U76qYXkdeBk
  8. #248
    Dec 2014
    640
    Nice!!!
  9. #249
    Jun 2006
    475
    Yes...... Very Nice!!!!
  10. #250
    Jun 2011
    39
    Fantastic! Absolutely mezmirising!
  11. #251
    May 2006
    2420
    Thanks guys.
    Well the build part is coming to a close, only been about 7 years !!!
    I put a few limits on the machine over the weekend, still need to put home switches but for now will use the limits as home switches.
    Unfortunately time and money is a little short at the moment so the final finishing covers and painting might be a while, in the meantime I have a few jobs to push through, some paid but mostly unpaid ones for friends.
    I did try a couple of inlays to see how it handles that, pretty happy with the results, kept them quite small to push my luck, the tail on the cat is very thin. Will make these into trinket boxes for my kids, daughter likes cats and son likes Yoshi, lol.
    Russell.
  12. #252
    Dec 2014
    640
    Nice!!
    Quote Originally Posted by epineh View Post
    Thanks guys.
    Russell.
  13. #253
    May 2006
    2420
    Been using the machine a fair bit lately, mostly timber work but I did have a go at milling a double sided PCB, actually a couple of attempts. It helps to set path blending when you are working with tiny copper tracks, also being careful with your origin reference points.
    Any way here is a photo of one I prepared earlier, I designed the board with a combination of through hole and surface mount parts, for easy prototype fabrication at home and also easier final assembly. (hopefully)
    Pretty happy with the results, isolation milling done with a 20 degree V cutter, 0.2mm depth of cut. Used a 1.8mm endmill to area clear the larger areas.
    While I am happy with the results, a toolchanger would have made life a lot easier.
    Russell.
  14. #254
    Jun 2006
    475
    Russell.
    Nice!
    Sent from my GT-N8010 using Tapatalk
  1. My CNC Bender Build
    By supahonkey in forum Bending, Forging, Extrusion...
    Last Post: 11-20-2015, 04:26 AM
  2. Neat Bender and how to build one!
    By Al_The_Man in forum Uncategorised MetalWorking Machines
    Last Post: 12-11-2012, 06:47 AM
  3. Not another CNC bender build
    By wes_mcgee in forum Bending, Forging, Extrusion...
    Last Post: 01-10-2012, 12:00 AM
  4. self-build electromagnetic sheetmetal bender...
    By 307startup in forum Bending, Forging, Extrusion...
    Last Post: 05-28-2011, 03:32 PM
  5. Looking 4 someone that would like to build a mini cnc tube/pipe bender for 3/8
    By dbtoutfit in forum Bending, Forging, Extrusion...
    Last Post: 10-19-2006, 03:45 AM
