587,792 active members*
3,679 visitors online*
Results 1 to 2 of 2
    Jul 2012
    28
    Anodizing and brass..
    Hi guys,
    I have a question I'm hoping someone on here can help me with.
    I want to anodize an aluminum part, the issue is the part contains brass bushes pressed into blind holes, that I am having a lot of difficulty removing without damaging.
    My question is will the brass cause problems if I anodize the part with the brass bushes. I know that sulphuric acid corrodes ferrous metals, but will it do the same with brass. Also will it affect the finish of the anodizing?
    Many thanks in advance.
    John.
    Jan 2005
    15362
    Re: Anodizing and brass..
    lew90nicis
    It will contaminate the Anodizing process, the bushing will have to be removed, one way to get the bush out is to put a thread in it, relieve the front part of a bolt/screw & screw it in, Put a washer down at the bottom of the hole, then screwing the bolt/screw in will push/pull the bush out
    Mactec54
  1. Home Anodizing. Low Current Anodizing. 720 Rule
    By kreutz in forum Mass finishing equipment/media/strategies
    Last Post: 11-29-2019, 04:13 PM
  2. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  3. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
  4. anodizing
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:22 AM
  5. Anodizing?
    By Klox in forum MetalWork Discussion
    Last Post: 05-03-2005, 06:46 PM
