We are looking at a couple VF-0Es with the 10,000rpm 20HP spindle. I have read quite a few posts about the 20HP actually being substantially less than that at most RPMs. I'm assuming that they get 10,000rpm by changing to a different pulley ratio and that this would reduce torque in all rpms. Do the 10,000rpm spindles have a noticable loss of torque compared to the 7500rpm version? I don't think the VF-0 has a gearbox so how does this effect tapping or making heavy cuts. I'm mainly working in aluminum so the 10K is nice but not if it will prevent us from doing 16-18mm tapping or making heavy roughing cuts. Any comments would be appreciated.
Thanks (again) in advance.
