587,686 active members*
3,425 visitors online*
Thread: AMC drives
Results 1 to 5 of 5
    Jan 2007
    66
    AMC drives
    My only CNC/machining experience has been with a 4-axis hobby cnc stepper setup on a homebuilt router table. I have recently purchased 5 Advanced Motion B25A40 brushless dc drives http://www.a-m-c.com/download/legacy/b25a40k.pdf to run a Bridgeport I'm converting. From what I understand, I need about 1000 oz-in to run my X, Y, and Z. I have a couple Baldor "big mho" servos I picked out of a scrap pile years ago. They are 192 oz-in but I think they will work for my rotary tables. My concern is, the amps are 120-400V dc and the motors are 24V max. I'm assuming the amps put out up to whatever I put in which will be 120. Can I crank the output voltage down enough to run these motors? Can I use a voltage divider?
    Thanks,
    Kevin
    Dec 2003
    24220
    Quote Originally Posted by ka67_72 View Post
    I believe you are referring to Voltage not current (amps)?
    The drives are in fact 120 to 400volts DC then your 24vdc motors are not suitable.
    It is possible to apply drive voltage up to 150%max. of motor voltage but this would be too extreme.
    Al.
    Albert E.
    Jan 2007
    66
    Would it be a bad idea to try using a voltage divider to drop the output voltage down?
    Thanks,
    Kevin
    Dec 2003
    24220
    That wouldn't really work, best look for different motors.
    Al.
    Albert E.
    Jan 2007
    66
  1. Help with drives
    By ltoy in forum Mach Mill
    Last Post: 11-16-2006, 01:33 AM
  2. Pac Sci Drives
    By George41 in forum Stepper Motors / Drives
    Last Post: 10-29-2006, 11:24 PM
  3. Zip Drives
    By Mortek in forum Haas Mills
    Last Post: 08-02-2006, 08:42 AM
  4. Replies: 1
    Last Post: 07-24-2005, 12:31 AM
  5. can you ID these drives
    By SJ781 in forum CNC Machine Related Electronics
    Last Post: 04-28-2004, 03:16 AM
