587,524 active members*
3,410 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > AMC Advanced Motion Controls servo drive encoder to tacho converter
Results 1 to 6 of 6
    Mar 2008
    267
    I am using a coupleof AMC be25A20 brushless servo amps.
    They have a nice feature... apply the quadrature pulse trian and it will generate tacho signal internally to close the velocity loop.
    MAJOR PROBLEM the tacho gain is set to 22KHz for 1 Volt output.
    No way to change that on board. Worse still the goos people at AMC have scrubbed off IC labelsso hard to determine whihc chip(s) is used in the tacho circuit.
    The machine generates a 7500KHz signal under conditions of normal operating speed.
    Anybody out there with the knowledge of how to reduce the frequency for a decent signal output? Say 2 KHz/1volt!
    Aug 2014
    889
    Re: AMC Advanced Motion Controls servo drive encoder to tacho converter
    Can the velocity loop not be closed by supplying an analog 0-10v signal? Pump the the 7500khz into a DAC and feed the drive, voltage signal instead of pulses. I'm guessing this is for the spindle motor?
    Worse still the goofs/ people at AMC have scrubbed off all IC labels so it's hard to determine which chip(s) are used in the tacho circuit.
    I agree. But how else can they protect their intellectual property?
    Mar 2008
    267
    Two issues...
    My apologies for the spelling mistake..it was not meant to read goos people..it was meant to say good people..which was then misinterpreted as goofs.. sincere apologies.
    As for intellectual property.. i do not expect them to expose their art...just make it a bit more user friendly.. make it adjustable somehow.
    Sadly the analogue input pin is setup for +/- 60V tacho input. Going from quadrature to proprietary analogue signal i would need to match it to the stated range. . Not so happy a solution.
    Mar 2008
    267
    Good news ...
    I have implemented an external modification which has provided the requisite gain.
    Machine operates quietly and precisely.
    Following error is an order of magnitude lower.
    All around a good result.
    Aug 2014
    60
    zig how did You fix it ??
    Mar 2008
    267
    just as stated..external gain block in the feedback path...
    Do you have a similar issue with Your equipment?
  1. Applied Motion Brushless Servo with Renco R35i encoder 132W
    By SwampDonkey in forum For Sale Only
    Last Post: 02-21-2016, 11:13 PM
  2. Motion control with AC VFD inverter drive and encoder? (Theory)
    By thescamp in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-19-2014, 02:26 PM
  3. Replies: 1
    Last Post: 03-11-2014, 06:58 PM
  4. advanced motion servo drives
    By cueshark in forum Servo Motors / Drives
    Last Post: 01-16-2007, 04:42 AM
