587,178 active members*
4,955 visitors online*
Results 1 to 2 of 2
    Jan 2016
    0
    Aluminum Wind Vane Reproduction
    I'm looking to get a few of these made. I think this is Gold Anodized Aluminum. The dimensions are 4" x 3" x 0.032" This is a restoration project so as close to original in appearance as possible. The photos below are from an unused original part that I have. I tried the eMachineShop software and having never done anything like this, I could not figure out the 3D part. After about 5 hours I gave up.
    Apr 2013
    99
    Re: Aluminum Wind Vane Reproduction
    Don't need any 3d drawing that's a straight forward sheet metal part.
    For some one with a shear only slightly trick part is the attachment part that you would do with a die
    and you could get a die made for not to much probably a couple hundred buck or so
    really low tech mark it out and cut to the lines
  1. Relief art reproduction legalities
    By cc102030 in forum MetalWork Discussion
    Last Post: 02-18-2013, 04:34 PM
  2. vane vs vac??
    By shnitzel in forum DIY CNC Router Table Machines
    Last Post: 11-18-2010, 07:49 AM
  3. AV vane operated position sensors
    By Appalachiatools in forum CNC Machine Related Electronics
    Last Post: 04-18-2009, 05:14 PM
  4. Vane Position Sensors
    By frankg521 in forum CNC Machine Related Electronics
    Last Post: 07-31-2008, 01:06 PM
  5. 5 Vane Impelar
    By rpicker1 in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2004, 02:23 PM
