587,415 active members*
3,284 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Aluminum Finish on an X3
Results 1 to 18 of 18
    Jan 2006
    461
    Sieg X3
    Modified Spindle 6000rpm
    17/64 3 Flute GW Schultz Aluminum Specific Carbide Endmill
    Flood Coolant, Green Mist Coolant in High Concentration
    .1 DOC, 50% Stepover at Most, .005 Finish Pass, 25ipm
    Import ER20 Collet and Tormach Collet Holder
    Bolted To Fixture Plate- Fixture Plate Held In Vise
    .0005 Total Measured Runout/Vibration
    The issue that I am having is this, I am getting a poor surface finish on any cut I make. Be it a pocket or a contour. The coolant is doing a pretty darn good job of keeping the cutting area clean. The poor finish looks like fine lines that run vertically on the sides of the pocket or contour, its a very slight scalloping. It occurs on all sides of the pocket and the sides of the contour, regardless of direction, so I dont believe it is caused by head misalignment.
    Is this caused by the runout/vibration. I say runout/vibration because just turning the spindle by hand, there is no detectable runout according to my .0005 Last Word Indicator. At 6000rpm, the needle will swing a tiny bit, so that is why I say runout/vibration.
    Any suggestions. Thx
    Nov 2003
    154
    .005 might be a little light. I would try to leave a little more say .02 to .03 for the final at least. You also don't say if you are climb milling or not. This will have a big difference on the finish. How new is the finishing end mill? Is it a dedicated finishing mill and not the one you used for roughing? Is it a long end mill? This will tend to vibrate or skip if long and light light cuts. Is this finish with all end mills or just this one? What type of aluminum? Why the odd size of end mill? Is this a resharp?
    There are a lot of factors which can play into this.
    It sounds like a rigidity problem!
    Try putting as large a diameter pin in the spindle as you can, and let it stick out as long as at can. Then place an indicator up close to the spindle nose, and set it to zero. Then with your hand try to move or bend the pin! This will show any looseness in the machine, and help you adjust / tighten it up!
    Also, a cheap or reground end mill can also produce a similar finish, as not all flutes are sharpened equally or concentric.
    Hope this helps!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jan 2006
    461
    Okay, I bumped up the finishing pass to .015. Climb Milling. Its the same endmill I use for roughing. Its a general purpose aluminum cutter. The endmills LOC is .75. Its chucked up to just above the flutes. Finish with all end mills. I noticed the same problem when I was cutting with a 2flute 1/2in held in a end mill holder. 6061-T6. Odd size because they had em cheap, and they were brand new, but just odd size so didnt sell. The finish was the same on the first hole as on the last.
    Sadly, I dont believe there is any way I can tighten up the spindle, which is the only place I would think would move with this light a cut. There is a discussion going on about making the x3's column more rigid, but I havent attempted it yet, and with this cut being so light I don't think it would be a factor.
    Should I increase the finishing pass feedrate. There is the option for it under mastercam for pocketing, but not for contouring.
    Nov 2005
    52
    Quote Originally Posted by pzzamakr1980 View Post
    Sieg X3
    "At 6000rpm, the needle will swing a tiny bit, so that is why I say runout/vibration."
    Please remind me to never loan you my tools.
    Increasing the feed rate increases the roughness or resolution between the high & low spots, try increasing RPM and decreasing feed just for a .01 pass. It's like cutting a thread, the more TPI the finer the surface!
    Also, end play in screw or bearings can give a chatter like finish.
    Widgit
    Jan 2006
    461
    Hardy har har. I guess if I was doing something wrong with my tools, I would probably be breaking the little 1/16 bits I use. If you dont have something constructive to offer, dont say anything at all. I'm just kidding... I actually thought the remark was kinda funny. Only kinda though....
    But seriously, when the Indicator moves between the the hash marks .0005 what else do you call it besides runout.
    Thank you Widgit, I will give that a try. Thats what I thought you were supposed to do for a finish pass, but someone else had told me that you should increase the feed rate, which I thought was contrary to common sense, so I ignored him. In all fairness, I probably just misunderstood him in the first place since he does this stuff for a living.
    Nov 2005
    52
    Sorry, but I couldnt resist. Only someone that really does it for a living would truly appreciate the tool thing. I didnt think you were actually bearing the indicator on a rotating spindle though it sounded like it.
    Anyway, the others have told you correct. It could be anything but likely a rigidity problem. Perform a test...go to a large end mill, say.750 dia or something like that and make cuts. If the same thing exists then its either the spindle or the holder. Then try a solid endmill holder with the 3/4". If still a problem then you can probably conclude its the spindle.
    Jan 2006
    461
    Oh, I didnt even get that part. I didnt understand why you were giving me crap until you mentioned holding the indicator in the spindle. LOL. Now I understand, and its even funnier. I just went back and read my original post and yeah, it does sound like I was holding the indicator in the spindle.
    Okay, I have used a 1/2in with a solid end mill holder and I got the same finish. I was only taking .005 on the finishing pass, so I will increase the finishing pass material and see if that helps. I'm thinking that it is the spindle, either because of vibration or runout.
    Right now the spindle is driven by a gear, which I've heard can contribute to poor finish. Is this the case? I intended to replace that with a belt drive at the spindle to lessen gear noise anyways, and this might be another good reason to do so.
    Also, I was looking at Vibrafree's website, and was curious if the mirror finish they are getting on their parts is typical of good cnc machine's only, or if the benchtop variety is able to make as nice a finish.
    Nov 2005
    52
    Oh heck yes. A tight toothed belt and pulley system is going to be better than a gear drive first of all. With gears, you have to have a small amount of backlash for lubrication between the teeth. Which is going to bounce back and forth as the cutter goes from load, to no load. It gets REALLY bad when you are using a radius-endmill because the flutes are pretty much vertical with the centerline of the cutter (no helix).
    Jan 2006
    461
    Okay awesome, then I will do that this week while I wait for replacement metal to come in. Thank you Press.
    Also, I was wondering if anybody has a good example of how a slot finish or pocket finish is supposed to look. I know Eric's work is always shiney and beautiful, but I was curious if its the same on the slots/contours as it is on the face milling. Is this the case Eric, or are the finishes as smooth as they look?
    Jul 2004
    374
    I noticed you are using a G.W. Schultz endmill, which we use from time to time. By chance is that a GWA series? If so, how much use does it have and have you ever used it for cutting anything other than aluminum?
    If cutting aluminum, never use an end mill thats been used in other metals like steel! A brand new end mill will side cut to a perfect 32 finish if it is a quality end mill! Solid carbide end mills are usually better, as they do not bend or flex!
    Stoning a slight radius on the points will also improve the finish from the end of the end mill. Also, always climb cut the last .005 -.010" and do it wet!
    My Bridgeport clone's maximum speed is 1280 RPM, and has a maximum feed of 30 IPM. And my parts always come out shiny and smooth!
    As for face mills, well, they are definitely not all the same! the angle of the inserts, and the rake angle which they are mounted is not all the same! Also, the edges of the inserts are not all razor sharp. Most are actually dull, but work excellent in steels and cast iron! When I bought my 2" & 3" face-mills, I made sure they took the same insert SEAN-42AFN As this insert has a razor sharp edge, and is 1/2" SQ.
    Also, I agree 100% that you need a corrugated belt or V-belt for the spindle, gears are great if all you do is muscle down steel & cast iron blocks all day long! The gears will give enormous power, but not smooth speed!
    Widgit
    Jan 2006
    461
    Yes, I'm pretty sure that that is the tool type. GWA. Its only been used on aluminum, and that was the first time I've used that tool.
    Jul 2004
    374
    Okay, the GWA leaves the most beautiful finish on pocket floors that I've seen from any tool. Unfortunately, it is a delicate tool, so if you've plunged with it or use it for aggressive roughing, it may be damaged.
    Your finishing feed is too low. Try more like 40 inches/minute at 6000 rpm. Leaving 0.005"-0.010" is ideal for your finish pass, but not more.
    I don't know what kind of coolant you have, but a water soluble semi-synthetic is best. A full synthetic general purpose coolant will leave a slightly more dull finish.
    I'm not crazy about the 0.0005" runout. Have you tried "tapping in" your tool to reduce the runout?
    Have you tried taking a finish pass on a straight edge yet? (is the finish quality problem localized to corners?)
    If you can post a picture of the finish, that would provide quite a bit more information.
    Jan 2006
    461
    Well, the pocket floors look perfect. Its not the bottoms, its the sides. Its has been used for plunge cutting, but the tips are still razor sharp, as are the flutes. I have been pretty gentle with the end mill, because I have been scared of breaking them since I could only afford two good quality carbide mills. The deepest I ever take per pass has been .01 and at most a 50% stepover. The coolant was listed above and it is water soluble. I dont have any idea what "tapping in" a tool is, so chances are I never have. The problem is with any side cutting such as the walls of pockets or contours, not just corners. Ill be glad to post a picture of the finish tomorrow.
    Jul 2004
    374
    Okay, then runout is your problem. First of all, I have never been able to achieve extremely smooth walls with small diameter GWA series tools, regardless of SHANK runout. (Data Flute AFI or AFDH series produce better wall finishes, but worse floor finishes)
    If your tool is installed in a collet, the collet has the ability to "deform" (and remain) under impact. Use your indicator and tap your tool until the runout is eliminated in the spindle. Of course, be careful not to damage the tool. I place a long rod on the tool shank near the spindle and tap on the other end of the rod.
    Get rid of that runout and I think you'll see better results.
    Jan 2006
    461
    Thank you. Ill give that and the belt drive a try.
  1. How to finish aluminum?
    By jason_n in forum DIY CNC Router Table Machines
    Last Post: 04-07-2016, 01:51 PM
  2. How do I finish Aluminum?
    By klick0 in forum MetalWork Discussion
    Last Post: 02-13-2008, 07:36 AM
  3. How to get a nice finish in aluminum?
    By Zumba in forum Mass finishing equipment/media/strategies
    Last Post: 04-26-2006, 12:50 PM
  4. Getting a nice finish on aluminum?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 11-19-2005, 08:00 AM
  5. Aluminum Matte Finish
    By Tazzer in forum MetalWork Discussion
    Last Post: 04-13-2004, 04:31 PM
