587,792 active members*
3,300 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Alarm 122 and 123 on my 1994 Haas VF-1
Results 1 to 7 of 7
    Jan 2008
    5
    I just replaced the DS307(GPD503) spindle drive on my Haas VF-1, checked the parameters, started up the machine and ran the spindle warm up program which ran fine. But when I tried to load the tools, it started giving ALARM 123 and then 122. When I opened the back panel, I could see the heating element (with metal enclosure) next to the drive getting red hot. When I powered off and powered on, the heater (regen?) gets red hot and gives me the two alarm codes. Whatz wrong? Is my wiring to the drive wrong or something else? Please help, I have demo to be shown on the machine within 2 days.
    Thanks,
    Harry Amble.
    Feb 2009
    64
    Message
    What is the alarm message?
    Nov 2007
    1702
    I don't know the early machines very well, but the regen resistor is controlled by the spindle drive. That suggests that either you wired it wrong on installation or there is something wrong with the new drive.
    That resistor gets connected to the motor only when it's slowing down (to absorb the generated current and stop the spindle). If it's 'on' all the time, that means the drive isn't switching it in and out of circuit properly.
    Greg
    Jan 2008
    5
    Quote Originally Posted by James L View Post
    The Alarm messages (synopsis) are:
    123: Spindle fault
    122: Overheating of regen
    Jan 2008
    5
    Quote Originally Posted by Donkey Hotey View Post
    Greg,
    You may be right. I am using the GPD515 connecting diagram to connect my replacement of GPD503 (DS 307) drive. Maybe the connection is wrong. BTW what is the heating elements (with ribbed elements) next to the drive which are enclosed in a U shape metal enclosure?
    Thanks,
    Harry Amble
    Mar 2008
    95
    p
    Feb 2009
    64
    Heating Element
    Unless I'm mistaken, I believe the heating element's function is to burn off the residual charge in the capacitors.
  1. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  2. Alarm 157 Haas VF3-SS
    By rshields21 in forum Haas Mills
    Last Post: 12-09-2011, 09:03 AM
  3. DNC to Haas mill (1994) with USB laptop?
    By ralph@nes in forum DNC Problems and Solutions
    Last Post: 02-16-2008, 07:53 AM
  4. Haas VF2 ALARM 127 &115
    By grease in forum Haas Mills
    Last Post: 10-18-2007, 09:31 PM
  5. 1994 haas vf 2
    By duckslayer in forum CNC Machining Centers
    Last Post: 01-13-2007, 04:44 AM
