587,086 active members*
3,171 visitors online*
Results 1 to 7 of 7
    Nov 2012
    6
    Air Bladder ?
    Those of you building water pans that have the air bladder under the pan, how are you dealing with rust inside the bladder? What about the dirty water going to the bladder and sediment forming in the bottom?
    Nov 2012
    64
    It's a good question that, its something I'm wondering about as well..
    Jun 2009
    226
    I use Sodium Nitrite (not Nitrate) and Physum 20. The Nitrite takes care of the rust and the Physum takes care of algae. It doesn't take much , works great, and is cheap.
    I also use a 60 mesh screen on the return to the tank and it keeps most of the larger particles out of the tank. When I close down in the winter, I empty the tank and clean it out however I get very little sediment out of it.
    I don't have the exact formula to mix the quench since the shop is closed for the winter but it's here on the zone someplace. Use the search for Sodium Nitrite and Physum.
    Willy
    Nov 2012
    64
    Thanks for that info Willy, I'm just at the stage of racking my brains which way to go with the pan, good to get another vote for the sodium nitrite mix as well.
    Jun 2009
    226
    Small correction. It's Physan 20.
    Willy
    Mar 2009
    924
    Here is a recipe that was posted by plain ol bill some time ago. I believe the general consensus is to use sewer tracing dye instead of food grade dye now:
    PLASMA QUENCH RECIPE
    Here's the recipe for home-made PlasmaQuench
    1/4 pound of sodium nitrite powder ($15/pound)
    1 teaspoon of Physan 20 ($8/8oz bottle)
    1 oz Ultramarine blue food-grade dye ($5/oz.)
    Mix well, treats 75 gallons of water.
    tracing dye:
    Blue Sewer Water Tracing Dye 16 oz Bottle | eBay
    (a LITTLE goes a long way!)
    sodium nitrite:
    10 lb Pail of Food Grade Sodium Nitrite NANO2 99 Free Flowing Granular FCC | eBay
    Physan 20:
    Physan 20 1 Gallon Gal Fungicide Algaecide Bactericide Concentrate Lawn Grass | eBay
    The physan 20 has many uses too, like your mill coolant system to keep tht ugly smell away or your fountain to keep the algea away.
    These quantities will last a long time. I have a 400gl table and have only changed water once in two years, I do have to replenish from evap but not often.
    WSS
    www.metaltechus.com
    Mar 2009
    924
    Forgot to mention the particle in the tank problem, We use a baffle right before the drain/fill holes. They are 2.5" npt fittings and the baffles stop any heavy particles from going down the drain so to speak.The lighter sediment gets mixed when draining and will pop right out if you fill straight away, pushing out all the dirty water into the tray.
    WSS
    www.metaltechus.com
  1. Air Bladder design problem, help please !
    By MetalHead6263 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-08-2012, 07:02 PM
  2. Strippit LVD 1250 H20 Bladder Kit
    By geofffinlay in forum Maintenance DIY Discussion
    Last Post: 06-14-2011, 03:07 PM
  3. Strippit LVD 1250 H20 Bladder Kit
    By geofffinlay in forum Want To Buy...Need help!
    Last Post: 06-13-2011, 05:58 PM
  4. Air Bladder Question
    By Normsthename in forum Waterjet General Topics
    Last Post: 04-25-2008, 06:09 PM
  5. looking for bladder molding info!
    By ukktor in forum Moldmaking
    Last Post: 01-29-2007, 03:31 AM
