587,180 active members*
4,964 visitors online*
Results 1 to 2 of 2
    Advice Needed on DIY Project
    Hi guys,
    I am new to plasma cutting and need someone to review this conversion project I am working on to convert a laser system to plasma.
    If you could just provide specific things you see as causing an issue and why. It would be much appreciated.
    https://youtu.be/9iPv7MkFwjc
    Mar 2019
    6
    Re: Advice Needed on DIY Project
    My main question is, what are you trying to achieve by doing this?
    I assume you want to cut thicker material?
  1. Advice Needed for New CNC Lathe to buy or Project
    By Cartierusm in forum Uncategorised MetalWorking Machines
    Last Post: 12-04-2016, 09:14 AM
  2. [ADVICE NEEDED] Z-Axis not moving - CNC builder needed
    By baodogg in forum Australia, New Zealand Club House
    Last Post: 06-03-2014, 12:42 PM
  3. Help With Project Needed - Guru Needed Please
    By cuetipper in forum DIY CNC Router Table Machines
    Last Post: 12-03-2012, 10:58 PM
  4. First Project.. Need advice
    By Mountaincraft in forum DIY CNC Router Table Machines
    Last Post: 06-01-2011, 12:09 AM
  5. Need some advice on my project
    By sigipa in forum Mechanical Calculations/Engineering Design
    Last Post: 09-16-2007, 05:43 PM
