587,143 active members*
3,332 visitors online*
    Jun 2013
    443
    Adhesive to bond 6061?
    I came accross a cheap sheet of 6061 20mm. Building a piece of equipment I am going to bond two pieces together at approx 500mm x 300mm to get a final piece after machining flat say 38mm. It will be bolted and also I want to glue for extra rigidity. I spoke to a Sika rep who said (after reading their site otherwise) that it was impossible.
    So this component will be subject to loads and vibration.
    Anyone know or recommend a glue? B
    Sent from my SM-S908E using Tapatalk
    Jul 2011
    400
    Re: Adhesive to bond 6061?
    Hysol EPK1C. Be certain that your parts are surgically clean before using. Do not apply excess pressure if bolting the assembly together wet.
    Jul 2018
    6457
    Hi Boydage - There are many epoxy and PU systems that will bond aluminium as you want. If you use a liquid epoxy I recommend you use a 25g glass tissue between the sheets. This will control your bondline and ensure you have no zero thickness bondline spots. 25g tissue is 0.2mm thick. Its important to follow the suppliers instructions. Epoxy does not like surface moisture so a flame prep or at least a hot gun over the surface before you apply the epoxy is good to remove the surface moisture.
    Loctite also supply anaerobic adhesives for metal to metal adhesive. They may be the go in this case, speak to your local loctite supplier. Peter
  1. Aluminum heatsink bond
    By screenzzzz in forum MetalWork Discussion
    Last Post: 08-05-2016, 12:01 PM
  2. 0 bond ( Multicam 3000)
    By jpfcosta in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-10-2013, 01:55 AM
  3. Best Adhesive for Gluing model kit parts to 6061 Aluminum
    By Dragnink in forum MetalWork Discussion
    Last Post: 09-25-2009, 07:36 AM
  4. Bond Pin to shaft
    By Karl_T in forum MetalWork Discussion
    Last Post: 12-02-2005, 06:18 PM
  5. Bond nuetral to ground?
    By Karl_T in forum CNC Machine Related Electronics
    Last Post: 11-27-2005, 07:12 PM
