587,577 active members*
3,317 visitors online*
IndustryArena Forum > CAM Software > Mastercam > adding loop sub routine
Results 1 to 4 of 4
    Apr 2008
    10
    not sure if this is a post problem or somthing i can even do but i have mastercam level 3 x2 mill and am writing simple contour tool paths for a
    proto trak conversational control (control turns my g-code into event programming when its loaded into the machine) i would like to add the looping into my g-code that mastercam puts out instead of the machinist adding it in later as a new event. i tried using the sub program check in the depth of cut
    box but this added the sub program to the begining of the program and proto trak is reading this as drill postion moves,went to change control definiton to sub program after main and found it already was. anyone got any ideas as to how i can do this. normaly only use cam for my large vmc's put had a job that had to run in the proto
    Apr 2003
    3578
    Talk with your dealer and if you have a sample that works. this will help them try and build this in to the post.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Apr 2008
    10
    do you mean the mastercam dealer or proto trak? i assume mastercam only i dont have
    a working example in g-code i could give them a notepad of the prototrak conversational i know i cant make heads of tails of it hope they can.
    thanks for the reply
    Apr 2003
    3578
    Talk to the dealer and see if they have a conversational post for this control I know there out there.
    Cadcam
  1. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  2. question on closed loop vs open loop (servo systems)
    By boonie in forum Servo Motors / Drives
    Last Post: 11-09-2007, 07:30 PM
  3. Closed loop vs. open loop
    By pelesl in forum Benchtop Machines
    Last Post: 04-06-2007, 10:56 PM
  4. Lathe conversion - open loop vs closed loop
    By bhowden in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2006, 10:56 PM
  5. Closed loop....open loop?
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 06-26-2004, 10:02 PM
