586,035 active members*
3,838 visitors online*
Results 1 to 5 of 5
    Dec 2009
    100
    Actual rapid speed Mori NT 1000?
    Hello,
    Has anyone measured actual rapid feed rates in, say, a 2" envelope on both the B-axis head and the turret? Thanks for any help.
    Jun 2005
    142
    No, but I've noticed on our NZ that rapiding from Z axis home to either spindle (about 300mm) takes the same time using 100% and 75% override.
    The distance is too short for it's acceleration.
    I think a machine would need to be pretty awesome to accelerate to full speed and decelerate within a 50mm envelope.
    Dec 2009
    100
    Quote Originally Posted by zooloader View Post
    I agree.
    Aug 2004
    780
    NAH.
    According to specs, and mostly true, machines accelerate to full speed feed rates in approx 5-8 mm in general, or approx 0.3 seconds in time.
    95%+ of these weaknesses are due to usage of the machine with code, post processor and cam.
    None are necessarily wrong ! Very important !
    A good hand coded piece for the same is likely to do the op in 1/3 the time.
    BUT.
    It will run 100-200-+ % spindle load and axis load.
    This may or may not be relevant.
    Feb 2009
    6028
    In general, it depends on what axis. The Mori NV5000a1 that came out ~10 years ago would reach full rapid within 1/4 turn of the ballscrew. Lathes tend to be a little slower, but it really depends on the model and if it's box or linear guides and overall size of the machine.
  1. Is actual cutting speed slower or curved than straight lines?
    By zachary2001 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-27-2012, 11:34 PM
  2. Mori-seiki SL65 Slow Rapid
    By MrUZU1 in forum MetalWork Discussion
    Last Post: 01-24-2011, 02:48 AM
  3. Replies: 4
    Last Post: 08-11-2009, 10:31 AM
  4. 92' 88HS - actual feed/speed display?
    By esolatimore in forum Fadal
    Last Post: 03-26-2009, 01:21 PM
  5. rapid speed
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 03:23 PM
