587,753 active members*
2,906 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Accumulation of fog on rear side of front glass of cars
Results 1 to 5 of 5
    Dear all,
    Accumulation of fog on rear side of front glass of cars is a problem especially while driving through rains.
    Can a simple mechanism/equipment be thought of to wipe off the fog?
    Nov 2005
    1468
    Had a similar problem with my motorbike helmet visor. My breath would condense on the inside of the visor making it hard to see.
    Easy solution- I got a drop of washing up detergent and rubbed it onto the surface (just one drop) 'till it dried in.
    No more fog.
    Should work with cars too.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Nov 2008
    16
    Shaving cream,
    Try it on your bathroom mirror, if you have one
    Jul 2008
    498
    I use lemon pledge furniture polish. On car windscreens (inside and out), on ski googles, mirrors and eye glasses.
    However, hot air blowing on the inside of the glass will prevent fogging and running the AC in your car will too. You need to reduce the humidity on the inside which is acheived by running the air conditioning along with the heater, raising the temperature of the glass by using vents which blow directly onto the glass is necessary to clear fog quickly.
    I spent three years living in a place with over 3 metres of rainfall per year. I kept the car air conditioning on whenever driving to keep the car interior as dry as possible.
    My X2 CNC Brain Build: http://www.cnczone.com/forums/showthread.php?t=61345
    Gecko G250 wiring errors: http://www.cnczone.com/forums/showthread.php?t=68960
    Feb 2009
    6028
    Yea, it's called the defroster. If you have a Japanese car, turn on the air conditioner with the defrost. Most other cars turn it on automatically. The air conditioner sucks the moisture out of the air and blows dry hot air with the defrost.
  1. Replies: 13
    Last Post: 07-13-2010, 05:23 PM
  2. Front & Rear Tools
    By M250cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 07-07-2010, 09:06 AM
  3. Rotary Broaching Chip Accumulation
    By peter@slater in forum Videos
    Last Post: 06-25-2009, 01:35 PM
  4. Lathe with Front and Rear tool posts
    By slammers in forum Mastercam
    Last Post: 05-31-2009, 10:49 PM
  5. RFQ- Small job on a front and rear panel
    By Dougie085 in forum Employment Opportunity
    Last Post: 04-19-2008, 01:17 AM
