587,600 active members*
4,291 visitors online*
Results 1 to 4 of 4
    Sep 2012
    182
    Ac spindle temperature sensor?
    Hi I'm trying to fault find a drive and need to mimic the signals on CN2. I have a spare position/speed sensor but can't find the details for the temperature sensor.
    can I use a resistor and if so what value should I use?
    Aug 2007
    793
    Quote Originally Posted by landslide1 View Post
    May be this will help
    Nov 2012
    1272
    Re: Ac spindle temperature sensor?
    The sensor inside spindles and motors is usually a thermistor. There is no single standard, it could be anything from 1kOhm to 100kOhm. A 100k potentiometer should cover most cases. Adjust it slowly until the temperature alarm goes away.
    Sep 2012
    182
    Thanks for your responses. it is a big help to get my drive sorted!
  1. Doosan lynx temperature sensor availablility
    By Centurus in forum Daewoo/Doosan
    Last Post: 12-22-2021, 03:19 PM
  2. Temperature sensor input to Kanalog?
    By mmurray70 in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-16-2017, 04:12 AM
  3. PM-25MV spindle temperature
    By yohan in forum Benchtop Machines
    Last Post: 06-16-2016, 08:15 PM
  4. Replies: 2
    Last Post: 10-22-2015, 10:35 AM
  5. Connection with Humidity sensor (4-20ma) and PLC or temperature controller
    By rainman in forum CNC Machine Related Electronics
    Last Post: 09-13-2008, 12:55 AM
