Bought the 3 sets of Panasonic servo MUDS041+MUMS041 used.
Connect to Mach3. The motors are working! But there is a mismatch.
Settings motors in Mach3:
2,500 encoder count x 4 for quadrature = 10,000 pulses per screw rev
And 10,000 / 5 pitch ballscrew = 2,000 steps per mm.
Attachment 265716
Run Mach3 at 300unit/min
Attachment 265718
The motor is turns! Then I measure the turns of the motor by tachometer and see: 2500prm!
But for such a turn: 2500prm x 5 pitch ballscrew = 12500unit/min need!
The difference between these values (12500 and 300) is 40 times!
Why? Where am I wrong?
I checked the parameter setting of servo and asked about it Panasonic support.
As I understand that electronic gear is not used.
In an attachment my Panaterm file.
Any thoughts?
