587,092 active members*
5,814 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Abrasive Wheel OK for cutting .5 OD X .058 walled 6061 tube?
Results 1 to 2 of 2
    Sep 2013
    55
    I always use a 96 tpi blade to cut most of my 6061. I have some .5 OD X .058 walled 6061 tube that binds the saw.
    Can I use an abrasive wheel cutoff saw or will the aluminum load the wheel?
    Thanks.
    Apr 2012
    90
    Re: Abrasive Wheel OK for cutting .5 OD X .058 walled 6061 tube?
    Aluminum will load the wheel. Do you have a chop saw or rip saw? These will work, just make sure the part is supported well. 96 Tpi is a lot for cutting aluminum. I would use around a 12TPI for that size
  1. Tube cutting; tin slots and tube ends
    By marineboy in forum Waterjet General Topics
    Last Post: 10-13-2009, 10:03 PM
  2. Replies: 4
    Last Post: 01-14-2009, 07:16 PM
  3. cutting die to cut abrasive cloth?
    By Syphonics in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2008, 04:15 PM
  4. FREE Online Video: Thermal & Abrasive Waterjet Cutting Processes
    By drem in forum Waterjet General Topics
    Last Post: 05-22-2007, 05:40 PM
  5. FREE Online Video: Thermal & Abrasive Waterjet Cutting Processes
    Last Post: 05-02-2007, 06:05 PM
