Originally Posted by
JerryBurks
I have 36" travel on X which is 914 mm, pretty close.
I use 15mm ball screws, works just fine but with 15mm pitch. That means even at higher feed rates it does not need to rotate that fast and they don't whip up to 500 ipm (12700 mm/min) that I tried. But then, I have higher torque NEMA34 steppers to compensate for the loss of leverage.
I would not recommend NEMA34 steppers with 5mm pitch ball screws. They usually have high inductance and don't like to spin very fast. That would really limit your speed (e.g. for a wood router).
You need to look up the formula for screw whipping limits (I have seen them somewhere but forgot) if the 16x5mm ball screws can handle your desired feed rates.
