587,669 active members*
3,371 visitors online*
Results 1 to 4 of 4
    Nov 2005
    5
    about 4140 hrc 45-50
    Hi everybody
    I have one 4140 45-50rc job. It’s “L” shape with 0.75” x 2.37”x7.0”. It has one 0.5 p.f. Blind hole on 7.0” side with depth 6.7” and top of the “L” shape I have 0.2” lip with horizontal & vertical full radius and there is other three tap holes. I’m thinking to do from 4140 annealed and then after does heat treat but my question is after h.t there is any chance to change dimension? This is first time I” m dealing with 45-50rc any suggestion it’s useful
    Oct 2005
    118
    I am in the process of doing a job out of the same material but only having to go to 35-40rc. The engineers had made up a Pre-Heat treat and a Post Heat treat machining prints. They left from .010 to .050 material to remove for finishing. So would say that it would move some.
    On this job they got out their 4 place pencil and scribbled all over it.(nuts)
    If you need any more info feel free to ask, I'll tell you what I know.
    Janos
    May 2006
    196
    In my experience with 4140 you will notice some distortion in your dimensions.
    Oct 2005
    251
    It will move. Plan to finish any dimension clsoer than .005 after heat treat. Good news is that 45-50 will cut readily with carbide tooling.
  1. Problems with 4140
    By HSPMInc in forum CNC Swiss Screw Machines
    Last Post: 11-21-2009, 02:11 AM
  2. 4140 r templado vs 01
    By mxmachinist in forum Spanish
    Last Post: 11-11-2009, 01:02 AM
  3. Capability in 4140
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 09-03-2009, 02:07 PM
  4. 1018 or 4140?
    By Rhodan in forum Linear and Rotary Motion
    Last Post: 06-05-2009, 03:44 PM
  5. WELDING 4140
    By MACHINE GOAT in forum Welding Brazing Soldering Sealing
    Last Post: 09-11-2008, 05:56 AM
