587,283 active members*
3,839 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > ABNORMAL CURRENT Fanuc Servo Amplifier
Results 1 to 16 of 16
    Apr 2012
    0
    Hello, I've got some turning machines which use the Fanuc servo amplifier A06B-6096-H206 that, at the moment of switching it on, displays the 8 alarm: ABNORMAL CURRENT.
    If I wait a period lasting from some minutes till an hour (depending on how recently the problem firstly appeared), switching the turning machine off and then on, the error disappears.
    Another solution we succesfully experimented is to warm up the servo with an hair-dryer for a couple of minutes and then switching it off and on.
    Starting from the fact that this malfunction is probably due to a simple ageing component, I'd like to know if anybody has identified which is the component/components that I have to replace.
    I find it irritating substitute an entire servo when the problem probably lies on a cheap component!
    Thank You in advance for helping me solving this.
    Regards
    Sep 2010
    1765
    Quote Originally Posted by Robyr View Post
    .......Another solution we succesfully experimented is to warm up the servo with an hair-dryer for a couple of minutes and then switching it off and on....
    by 'servo' do u mean the servo motor or the servo drive? I assume from ur description u mean servo drive but it seems more likely the servo motor actually has an issue, like it has moisture in it and the fault is really telling u it is time to get it cleans and reinsulated?
    Dec 2003
    24223
    I have come across this in some Fanuc systems and turned out to be the motor temperature sensor, if the feedback from this is wrong for any reason the control thinks the motor has overheated, which is usually due to excess current.
    Al.
    Albert E.
    Apr 2012
    0
    Quote Originally Posted by Al_The_Man View Post
    Al.
    If it is the temperature sensor, because with heating the servo amplifier does it work? I'm not heating the motor!
    Feb 2009
    6028
    Typical failed capacitor in the drive. Seen that one before many times.
    Apr 2012
    0
    Quote Originally Posted by underthetire View Post
    I agree with you! But which capacitor? Have you an idea?
    Thank You.
    Sep 2010
    1765
    probably the BIG ONE(s) - dc bus that keep bus voltage solid.... makes sense...would match all your facts and findings....
    Sep 2003
    26
    I agree bad cap or input voltage on the low side
    Nov 2010
    4
    Use a Blue Meter to check the bad capacitor. Normally is at the output section near the IGBT especially the SMD Cap. Blue meter is a must equipment to check Capacitor.
    Oct 2013
    6
    I'm thinking of checking two big caps you can see it in attached picture. I am right?Click image for larger version.
    Nov 2010
    4
    Normally, abnormal current is caused by: Bad IGBT, Bad SMD resistor under the IGBT and steel bar (shown in your picture) or small capacitor in the Control board (the board on top of your picture).
    Use DMM to check the value of resistor, replace if the value change.
    Blue meter for capacitor. Remember to discharge the capacitor before you test. Replace if ESR value is high
    For IGBT, just replace it because it is not easy to test a IGBT module.
    Hope this will help.
    Oct 2013
    6
    Is it possible to check resistors in board? Or should I dismount it from the board?
    Quote Originally Posted by KENGLIAN View Post
    Oct 2013
    6
    As I am very new, by IGBT you mean this part I marked in circle?Click image for larger version.
    Nov 2010
    4
    Yes. Confirm off board if value is not as indicated.
    IGBT should be FUJI 6MBP ## XX ###
    Oct 2013
    6
    Thank you for your answer. IGBT module is FUJI 6MBP50RA060-01 . Visually inspected all the capacitors on the control board, all seems okay( didn't see any blown capacitor). Now I will check the resistors .
    Oct 2013
    6
    I found some melted marks on board for a resistor Click image for larger version.
ID:	203556 Click image for larger version.
ID:	203558 If I understand you correctly i need to check all these resistors? Click image for larger version.
Name:	$(KGrHqEOKpYE1qzggcf3BNo1wff39!~~_3 (1) - Copy.JPG
  1. SV003 V abnormal current in servo
    By thesticker in forum Fanuc
    Last Post: 08-28-2016, 01:24 PM
  2. Fanuc servo amplifier
    By hotrob1 in forum Fanuc
    Last Post: 04-27-2012, 01:58 AM
  3. Fanuc servo amplifier alarm
    By KENGLIAN in forum Fanuc
    Last Post: 02-19-2011, 03:37 AM
  4. Servo Amplifier FANUC
    By Antonio Arguijo in forum Fanuc
    Last Post: 12-07-2010, 03:53 AM
  5. 438 Invertor abnormal current
    By bob1371 in forum Fanuc
    Last Post: 08-07-2007, 07:41 PM
