587,515 active members*
2,913 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > A stepper motor is a 2 phase AC synchronous motor?
Results 1 to 10 of 10
    Aug 2013
    5
    Hello,
    I have a movable equipment with a 4 leads AC synchronous motor (24V ac, 50/60Hz, 3 watts, 2rpm), I would like to control it easily as stepper in a school project, I've made the connections and indeed it works with full steps and micro steps (I'm still not 100% if there are errors like missed steps, or if it's harmful in some way to the synchronous motor).
    But before going forward, I must be able to explain this clearly.
    I've been doing some research, here are the best sources I have until now:
    «A stepper motor is a 2 phase AC synchronous motor»
    http://venus.ece.ndsu.nodak.edu/~glo...per_Motors.pdf
    «Basically it's a synchronous motor with the magnetic field electronically switched to rotate the armature magnet around.»
    http://minimaestro.as.arizona.edu/MA...es/step101.pdf
    «The AC Synchronous motors provided by Portescap are constructed in the same basic way as the permanent magnet motor except that each coil is supplied with AC voltage with a phase shifting capacitor across the coils.»
    http://www.cas.mcmaster.ca/~lawford/...ef/Stepper.pdf
    «The SLO-SYN motor is unique in that it has the capability of being operated as an AC synchronous, constant speed motor or as a phase switched DC stepper motor. In either case, it is classified as a permanent magnet inductor motor.»
    http://mcsupplyco.com/uploads/images.../SYNCGUIDE.pdf
    example of a synchronous motor datasheet:
    http://www.hurst-motors.com/document...m_Synch_DD.pdf
    I want more, so I would like to learn from other's experience/knowledge.
    I've been reading posts about steppers in this forum with excellent technical insights, can you give me a hand in this matter?
    Thank you
    Dec 2003
    24220
    That is unusually low voltage for a AC stepper, usually they run on 110 or 220vac.
    Some of the advantages are that they run at a constant 72 RPM on 60Hz or 60RPM on 50Hz (synchronous motor).
    The will not burn out when stalled, and have instant stop start.
    Al.
    Albert E.
    Aug 2013
    5
    The specs are really uncommon.
    Here are some pictures of the motor:
    Attachment 195298 Attachment 195300 green - original gear reduction; brown - motor
    Further tests showed that this motor alone (without its gear reduction) has 24 full steps per revolution (when driven as stepper).
    From my sources in the previous posts, I interpreted that the expected rpm of this synchronous motor alone (without gear reduction) when driven by Vac @ 50Hz should be:
    (4*60*50)/24 = 500 RPM
    The explanation for the rating of 2 RPM could be that the brand already took its original gear reduction in consideration, that should be a reduction of 250:1.
    Doing this without datasheet is taking some time.
    a stepper motor have 2 phase, 3 phase, 4 phase, 5 phase.
    May 2014
    2
    Smile Re: A stepper motor is a 2 phase AC synchronous motor?
    I came accross a very interesting website with more info on this product: Synchronous motors, Synchronous engine - All industrial manufacturers - Videos
    Aug 2019
    11
    i have a couple of slosyn dc stepper/ac synchronous motors, does anyone know how to wire them for ac synchronous operation? they have 6 wires, 2 are centre of coils and then 2 pairs are the ends of each phase winding, its 4.2v 1.9a 200 teps per rev i think this is the dc spec, some things on nameplate left blank they are M062-FD04 model, great solid motors, like to see if they can be put to good use...
    Dec 2003
    24220
    The Slo-Syn version that were made for operation on the 120v or 240v service were bi-polar - 4 wire two coil motors.
    One pair across the mains power, the other used a resistor and capacitor in series with the second winding.
    Albert E.
    Quote Originally Posted by elektr View Post
    The explanation for the ratingt of 2 RPM could be that the brand already took its original gear reduction in consideration, that should be a reduction of 250:1.
    You said you drove it with a stepper driver? That would suggest it is two independent phase windings. An alternative for a four wire ac-synchronous motor is that it's a three phase with a center tap. Easy enough to just measure with an ohm-meter.
    If you have an oscilloscope and it can be back driven, measure each connected pair with the scope while you back drive at a more or less constant speed. Triggering on the zero crossing should let you capture the waveform nicely.
    I'll bet this is a two independent phase motor, stepper design. Steppers are synchronous motors.
    Dec 2003
    24220
    Quote Originally Posted by StrawberryBoi View Post
    Are you confusing this with the original 2013/14 eight year old posts?
    These look like a different motor?
    Albert E.
    Quote Originally Posted by Al_The_Man View Post
    I was responding to the original topic...
  1. Stepper motor Driver PHASE TO AUTOMATION
    By Flemilla in forum Stepper Motors / Drives
    Last Post: 05-15-2015, 04:46 AM
  2. how to determine tha phase of stepper motor
    By alihureiby in forum Stepper Motors / Drives
    Last Post: 12-20-2013, 03:05 AM
  3. 3 phase stepper motor sources?
    By Kingjamez in forum Stepper Motors / Drives
    Last Post: 03-17-2013, 06:47 PM
  4. 2 PHASE stepper motor driver
    By stepperdriver in forum News Announcements
    Last Post: 10-26-2009, 08:04 AM
  5. 5-phase stepper motor with g201
    By ahmed in forum Gecko Drives
    Last Post: 04-17-2006, 05:13 PM
