587,470 active members*
3,150 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 93 Haas VF2 Homing Questions
    Apr 2007
    17
    When I home out my machine it alrams sometimes.
    I have swapped cards and still same problem.
    I have replaced the x-axis limit switch.
    But the braket underneath the table was removed as well.
    The one that roll upon to the switch. Which triggers it.
    Does anyone know how to set this properly??
    Mar 2005
    1498
    071023-0703 EST USA
    Rcky123:
    Ideally I believe the limit switch should actuate 180 deg from the encoder once per revolution marker. However, the amount of hystersis and variability in the switch and the HAAS direction of use of the change of state might bias this some.
    All our machines have mechanical limit switches, contrasted to prox switches, and we have never had to adjust a limit switch.
    A side moving actuator on a prox switch will have a trigger point for the side motion that is a function of gap when the plate is over the prox. If the gap is 0.1" then you will be closer to the axis of the prox for the trigger point than if you have a gap of 0.01" .
    Apr 2007
    178
    if you are getting zero ret margin too small then you need to adjust the grid offset for the particular axis then watch the dist to go on the zero ret page it should be .118 optimally just mess with the number in the grid offset parameter to change the end value.
  1. Homing question
    By IQChallenged in forum Machines running Mach Software
    Last Post: 06-23-2007, 12:29 AM
  2. HRT 210 homing
    By JAVB in forum Haas Mills
    Last Post: 12-07-2006, 07:44 PM
  3. Haas Lathe Questions - Lots
    By 1ctoolfool in forum Haas Mills
    Last Post: 08-14-2006, 12:47 AM
  4. Homing
    By Sanghera in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-10-2006, 12:47 AM
  5. homing vs 0,0,0
    By planeflier in forum Mechanical Calculations/Engineering Design
    Last Post: 02-08-2006, 04:02 AM
