587,482 active members*
2,928 visitors online*
Results 1 to 6 of 6
    Aug 2018
    2
    Exclamation 80w Chinese Laser and problem with Ruida rdc6442s
    Hello everyone and thank you in advance for your help.
    I bought an 80w co2 laser machine last week from this ebay vendor https://www.ebay.it/usr/iddmart2011
    Today I was able to put the laser machine into operation, but I had serious problems with its operation. During the first attempts to turn the machine on, the display show the phrase "Connecting to controllet" but it remained blocked for a few minutes before starting. Then I tried to start a laser processing and it happened that after a few seconds of laser operation, the processing was interrupted and a reset was made and then asked if I wanted to resume processing. This problem gradually became more frequent, in fact the machine did not work for more than 2/3 seconds and then made a reset. At the moment I can not even start a process because it locks continuously showing the screen of resetting on the display. In this link you can see screenshot and a small video demo.
    https://photos.app.goo.gl/8EdAqUHewj4tqyir9
    I deactivated all (red point, laser powe supply, air, ecc.) leaving only the controller active and the step motors but also in this case the machine don't work.
    What do you think?
    Aug 2018
    2
    Re: 80w Chinese Laser and problem with Ruida rdc6442s
    Please, nobody can help me?
    thanks
    Jan 2008
    940
    What does the seller say. I have had good luck with my seller and any problems most don't want bad feed back so they do try to help.
    Oct 2015
    96
    Check grounding (earth) wiring on machine, especially unscrew and check grounding connector. They sometime do NOT connect properly grounding wire to machine body. This can cause unpredictable actions like this.
    Polish @ Éire
    Aug 2016
    75
    >>Check grounding (earth) wiring on machine<<
    +1 to that suggestion
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Apr 2006
    251
    Check ALL connections. Something could be loose.
  1. I need the vendor settings file for Chinese SGH350 Laser with Ruida board
    By Marco_France in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-06-2022, 12:22 PM
  2. RUIDA INTERFACE - chinese laser 50W - KH3050
    By Audrey in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-06-2018, 12:41 PM
  3. I need the vendor settings file for BODOR BCL1006XUF Laser with Ruida RDC6442S board
    By Cristiana in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2018, 02:01 PM
  4. Converting from Ruida rdc6442s to controller with no file size linit
    By closeracing in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-08-2017, 08:01 PM
