587,579 active members*
3,380 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 5 axis breakout, TB6560 driver, 6 wire stepper
Results 1 to 2 of 2
    May 2012
    0
    A 6wire unipolar stepper + 5 axis breakout board + TB6560 single driver what I like to connect together (the 5 axis and TB6560 I bought on ebay, and the motor is unknown).
    Is it correct connection:
    TB6560 driver and 5 axis breakout: -CLK to GND. -CW to GND, -EN to GND, +CLK to XS, +CW to XD, +EN to XE
    And the motor:
    black-brown, black-yellow 6ohm; yellow-brown 12ohm
    blue-red, blue-green 6ohm; green-red 12ohm
    If I'm testing the motor with +power to the black and blue.
    And -power to the brown, green, yellow, red then the motor stepping one-way.
    But If I try to give power : +A brown to -A yellow, +B green to -B red then the motor just step 1 forward and 1 back or sometimes just maybe half step. And it's doesn't matter if I change the wires + to -.
    Is it normal or I'm doing something wrong here?
    Thanks for trying to help and sorry for my English.
    May 2012
    0
    Yep it's ok !! Why not?!
    All my problem was with the Mach setting..
  1. 3 Axis TB6560 CNC Stepper Motor Driver Problem
    By Overminde in forum CNC Machine Related Electronics
    Last Post: 05-23-2012, 11:09 AM
  2. Problem with CNC 4 Axis 3.5A TB6560 Stepper Motor Driver Board
    By bbbharvard_cnc in forum CNC Machine Related Electronics
    Last Post: 04-10-2012, 06:11 AM
  3. 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    By RCjunkie in forum CNC Wire Foam Cutter Machines
    Last Post: 01-24-2012, 04:45 PM
  4. TB6560 4 Axis CNC Motor Stepper Driver 3A 12-36V
    By vicsrc in forum Want To Buy...Need help!
    Last Post: 03-10-2011, 05:57 PM
