587,300 active members*
3,466 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4th axis programing
Results 1 to 11 of 11
    Mar 2008
    67
    4th axis programing
    Hi everyone , i have been using mastercam for quite sometime I know how program in 3d, but the company that i now work wants me to program in 4 using a 4th axis , i have spent alot of time trying to figure this out on my own, i do the design in solidworks then bring the file into mastercam x5, I need to have the part index on the rotary axis to cut features on 4 sides.
    thanks in advance
    J little
    Aug 2009
    986
    What's your question?
    Frederic
    Mar 2008
    67
    when you are writing the tool paths and you are switching between the sides do you keep the same work offset then shift the work in a0.0 to start then rotating the workpiece to a90.0 and son on.
    Dec 2010
    23
    Really depends, If your working on the COR (center of rotation) you can use one offset, and let the cam system post out the A commands, Ex. 1 tool does all 4 parts or however many then changes tools, be sure your clearance plane is enough to let rotary turn and not crash into your parts. I usually send Z home. Or another way is use 4 offets and then you manually set A0,A90,A180,A270, whatever your doing. Same with the clearance plane. Probably need alittle bit more info out of you to point you in the right direction.. Production run? or just a few parts? Just some insight, hope it helps
    Aug 2009
    986
    If you shift your tool plane without changing your WCS, then you will get A and B axis movements when you post your gcode.
    Frederic
    Dec 2008
    3123
    Quote Originally Posted by TXFred View Post
    Frederic
    +1 with Fred
    Your WCS is to be used in every op, it sets the rotation datum to zero
    the T & C plane is the index position
    If you create a plane that your machine cannot do, it should let you know when posting
    Check / read the comments at the top of yout .PST file for how to use and get the correct code.
    Jan 2010
    4
    Hello Friends,
    I have same problem like functionbikes. I'am trying to program 4th axis, but something is wrong. Maybe someone can help or give a little or big advice? I have YCM VMC machine with 4th (3+1) index axis. I'll Atach file that Iam trying to do. Maybe someone will look it? Only what works is "Axis substitution option" but I know it's wrong choice, I need That 4 th axis rotate part at needed position. How to do that?
    Attached Files Attached Files
    Dec 2004
    55
    Frederic
    Man I love it when I find my answers in others posts. Thanks for the indirect help!
    Dec 2004
    55
    Spoke too soon, I get my A axis moves now but it wants to give each axis position a new offset, (G55, G56, G57 etc.). How do I make That change? I have all the planes set to -1.
    Sep 2011
    0
    Quote Originally Posted by juxtoposed View Post
    set them all to 0
    Oct 2011
    0
    Setting to zero on the plane/view wont help i dont think.
    Go to misc values and set "lock on first wcs" on all of your indexed toolpaths.
    Ps. Wcs should always be top. Always.
    The tool plane and comp/construction plane are set to the plane that you want to index to. By the way a0, in mastercam is to the right of the part from the right side view, NOT the top edge from the Rs view
  1. C axis programing problem (Meldas 635)
    By Koalas in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-25-2023, 07:45 AM
  2. Looking jobs in 5 axis programing
    By a.kailasanathan in forum Employment Opportunity
    Last Post: 08-25-2010, 03:59 PM
  3. EIA programing on a mazak 350 with c axis
    By the mill kid in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-30-2009, 01:15 PM
  4. SL-30 programing ?
    By travis1 in forum Haas Lathes
    Last Post: 07-09-2008, 03:06 PM
  5. V2XT- DX32 : Programing Z axis Question
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2006, 04:46 PM
