587,773 active members*
3,128 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > 4th axis on Hurco VM10i
Results 1 to 6 of 6
    Aug 2014
    4
    Hi all,
    Just getting into programming the 4th axis on our Hurco VM10i, I'm using Mastercam to program in and cutting a part that basically has a thread to it. Problem I'm having is the 4th brakes each time it moves, the code is calling an "A" move each line so the machine won't really move at all between the brake/unbrake cycle. I saw a post from back when that said something about M32 but I don't have any of those in the code. Am I missing something here in the actual program or at the machine?\
    Thanks in advance!
    John
    Jul 2010
    492
    Re: 4th axis on Hurco VM10i
    here is the last thing i ran in the 4th axis. hurco vmx42
    m33/m32 is the lock on the 4th...
    Code:
    O0001(14088DC)
    (DATE=DD-MM-YY - 18-03-14 TIME=HH:MM - 11:27)
    (MCX FILE - Y:\IDFI\14088 DC ROTATING BLADE\14088 DC-1 ROTATING BLADE.MCX-7)
    (NC FILE - Y:\IDFI\14088 DC ROTATING BLADE\14088DC.NC)
    (MATERIAL - ALUMINUM INCH - 2024)
    ( T5 |  5/16 FLAT ENDMILL | H5 )
    N100 G20
    N102 G0 G17 G40 G49 G80 G90
    N104 T5 M6
    N106 G0 G90 G56.1 P51 X4.119 Y0. A-85.262 S9000 M3
    N108 G43 H5 Z1.6875
    N110 Z.7875
    N112 G1 Z.6875 F5.
    N114 X-4.1337 Z.6753 A-250.338 F100.
    N116 X-4.1397 A-250.602
    N118 X-4.145 A-250.958
    N120 X-4.1493 A-251.391
    N122 X-4.1528 A-251.887
    N124 X-4.1551 A-252.427
    N126 X-4.1562 A-252.997
    N128 X-4.1563 A-253.179
    N130 Z.6751 A-264.281
    N132 X-4.1558 A-264.848
    N134 X-4.154 A-265.401
    N136 X-4.1509 A-265.908
    N138 X-4.147 A-266.36
    N140 X-4.1421 Z.675 A-266.743
    N142 X-4.1366 A-267.051
    N144 X-4.131 A-267.242
    N146 X-4.1249 A-267.306
    N148 X-4.1189 A-267.238
    N150 X4.129 Z.6628 A-102.278
    N152 X4.1354 A-102.092
    N154 X4.1413 A-101.803
    N156 X4.1463 A-101.424
    N158 X4.1505 A-100.973
    N160 X4.1536 A-100.468
    N162 X4.1556 A-99.927
    N164 X4.1561 A-99.625
    N166 X4.1563 A-99.321
    N168 Z.6626 A-88.218
    N170 X4.1558 A-87.647
    N172 X4.154 A-87.097
    N174 X4.1509 A-86.592
    N176 X4.147 A-86.141
    N178 X4.1421 Z.6625 A-85.757
    N180 X4.1366 A-85.449
    N182 X4.131 A-85.259
    N184 X4.125 A-85.194
    N186 X4.119 A-85.262
    N188 X-4.129 Z.6503 A-250.223
    N190 X-4.1354 A-250.408
    N192 X-4.1413 A-250.698
    N194 X-4.1463 A-251.076
    N196 X-4.1505 A-251.527
    N198 X-4.1536 A-252.033
    N200 X-4.1556 A-252.573
    N202 X-4.1561 A-252.875
    N204 X-4.1563 A-253.179
    N206 Z.6501 A-264.281
    N208 X-4.1558 A-264.848
    N210 X-4.154 A-265.401
    N212 X-4.1509 A-265.908
    N214 X-4.147 A-266.36
    N216 X-4.1421 Z.65 A-266.743
    N218 X-4.1366 A-267.051
    N220 X-4.131 A-267.242
    N222 X-4.1249 A-267.306
    N224 X-4.1189 A-267.238
    N226 X4.129 Z.6378 A-102.278
    N228 X4.1354 A-102.092
    N230 X4.1413 A-101.803
    N232 X4.1463 A-101.424
    N234 X4.1505 A-100.973
    N236 X4.1536 A-100.468
    N238 X4.1556 A-99.927
    N240 X4.1561 A-99.625
    N242 X4.1563 A-99.321
    N244 Z.6376 A-88.218
    N246 X4.1558 A-87.647
    N248 X4.154 A-87.097
    N250 X4.1509 A-86.592
    N252 X4.147 A-86.141
    N254 X4.1421 Z.6375 A-85.757
    N256 X4.1366 A-85.449
    N258 X4.131 A-85.259
    N260 X4.125 A-85.194
    N262 X4.119 A-85.262
    N264 X-4.129 Z.6253 A-250.223
    N266 X-4.1354 A-250.408
    N268 X-4.1413 A-250.698
    N270 X-4.1463 A-251.076
    N272 X-4.1505 A-251.527
    N274 X-4.1536 A-252.033
    N276 X-4.1556 A-252.573
    N278 X-4.1561 A-252.875
    N280 X-4.1563 A-253.179
    N282 Z.6251 A-264.281
    N284 X-4.1558 A-264.848
    N286 X-4.154 A-265.401
    N288 X-4.1509 A-265.908
    N290 X-4.147 A-266.36
    N292 X-4.1421 Z.625 A-266.743
    N294 X-4.1366 A-267.051
    N296 X-4.131 A-267.242
    N298 X-4.1249 A-267.306
    N300 X-4.1189 A-267.238
    N302 X4.129 Z.6128 A-102.278
    N304 X4.1354 A-102.092
    N306 X4.1413 A-101.803
    N308 X4.1463 A-101.424
    N310 X4.1505 A-100.973
    N312 X4.1536 A-100.468
    N314 X4.1556 A-99.927
    N316 X4.1561 A-99.625
    N318 X4.1563 A-99.321
    N320 Z.6126 A-88.218
    N322 X4.1558 A-87.647
    N324 X4.154 A-87.097
    N326 X4.1509 A-86.592
    N328 X4.147 A-86.141
    N330 X4.1421 Z.6125 A-85.757
    N332 X4.1366 A-85.449
    N334 X4.131 A-85.259
    N336 X4.125 A-85.194
    N338 X4.119 A-85.262
    N340 X-4.129 Z.6003 A-250.223
    N342 X-4.1354 A-250.408
    N344 X-4.1413 A-250.698
    N346 X-4.1463 A-251.076
    N348 X-4.1505 A-251.527
    N350 X-4.1536 A-252.033
    N352 X-4.1556 A-252.573
    N354 X-4.1561 A-252.875
    N356 X-4.1563 A-253.179
    N358 Z.6001 A-264.281
    N360 X-4.1558 A-264.848
    N362 X-4.154 A-265.401
    N364 X-4.1509 A-265.908
    N366 X-4.147 A-266.36
    N368 X-4.1421 Z.6 A-266.743
    N370 X-4.1366 A-267.051
    N372 X-4.131 A-267.242
    N374 X-4.1249 A-267.306
    N376 X-4.1189 A-267.238
    N378 X4.129 Z.5878 A-102.278
    N380 X4.1354 A-102.092
    N382 X4.1413 A-101.803
    N384 X4.1463 A-101.424
    N386 X4.1505 A-100.973
    N388 X4.1536 A-100.468
    N390 X4.1556 A-99.927
    N392 X4.1561 A-99.625
    N394 X4.1563 A-99.321
    N396 Z.5876 A-88.218
    N398 X4.1558 A-87.647
    N400 X4.154 A-87.097
    N402 X4.1509 A-86.592
    N404 X4.147 A-86.141
    N406 X4.1421 Z.5875 A-85.757
    N408 X4.1366 A-85.449
    N410 X4.131 A-85.259
    N412 X4.125 A-85.194
    N414 X4.119 A-85.262
    N416 X-4.129 Z.5753 A-250.223
    N418 X-4.1354 A-250.408
    N420 X-4.1413 A-250.698
    N422 X-4.1463 A-251.076
    N424 X-4.1505 A-251.527
    N426 X-4.1536 A-252.033
    N428 X-4.1556 A-252.573
    N430 X-4.1561 A-252.875
    N432 X-4.1563 A-253.179
    N434 Z.5751 A-264.281
    N436 X-4.1558 A-264.848
    N438 X-4.154 A-265.401
    N440 X-4.1509 A-265.908
    N442 X-4.147 A-266.36
    N444 X-4.1421 Z.575 A-266.743
    N446 X-4.1366 A-267.051
    N448 X-4.131 A-267.242
    N450 X-4.1249 A-267.306
    N452 X-4.1189 A-267.238
    N454 X4.129 Z.5628 A-102.278
    N456 X4.1354 A-102.092
    N458 X4.1413 A-101.803
    N460 X4.1463 A-101.424
    N462 X4.1505 A-100.973
    N464 X4.1536 A-100.468
    N466 X4.1556 A-99.927
    N468 X4.1561 A-99.625
    N470 X4.1563 A-99.321
    N472 Z.5626 A-88.218
    N474 X4.1558 A-87.647
    N476 X4.154 A-87.097
    N478 X4.1509 A-86.592
    N480 X4.147 A-86.141
    N482 X4.1421 Z.5625 A-85.757
    N484 X4.1366 A-85.449
    N486 X4.131 A-85.259
    N488 X4.125 A-85.194
    N490 X4.119 A-85.262
    N492 X-4.129 Z.5503 A-250.223
    N494 X-4.1354 A-250.408
    N496 X-4.1413 A-250.698
    N498 X-4.1463 A-251.076
    N500 X-4.1505 A-251.527
    N502 X-4.1536 A-252.033
    N504 X-4.1556 A-252.573
    N506 X-4.1561 A-252.875
    N508 X-4.1563 A-253.179
    N510 Z.5501 A-264.281
    N512 X-4.1558 A-264.848
    N514 X-4.154 A-265.401
    N516 X-4.1509 A-265.908
    N518 X-4.147 A-266.36
    N520 X-4.1421 Z.55 A-266.743
    N522 X-4.1366 A-267.051
    N524 X-4.131 A-267.242
    N526 X-4.1249 A-267.306
    N528 X-4.1189 A-267.238
    N530 X4.129 Z.5378 A-102.278
    N532 X4.1354 A-102.092
    N534 X4.1413 A-101.803
    N536 X4.1463 A-101.424
    N538 X4.1505 A-100.973
    N540 X4.1536 A-100.468
    N542 X4.1556 A-99.927
    N544 X4.1561 A-99.625
    N546 X4.1563 A-99.321
    N548 Z.5376 A-88.218
    N550 X4.1558 A-87.647
    N552 X4.154 A-87.097
    N554 X4.1509 A-86.592
    N556 X4.147 A-86.141
    N558 X4.1421 Z.5375 A-85.757
    N560 X4.1366 A-85.449
    N562 X4.131 A-85.259
    N564 X4.125 A-85.194
    N566 X4.119 A-85.262
    N568 X-4.129 Z.5253 A-250.223
    N570 X-4.1354 A-250.408
    N572 X-4.1413 A-250.698
    N574 X-4.1463 A-251.076
    N576 X-4.1505 A-251.527
    N578 X-4.1536 A-252.033
    N580 X-4.1556 A-252.573
    N582 X-4.1561 A-252.875
    N584 X-4.1563 A-253.179
    N586 Z.5251 A-264.281
    N588 X-4.1558 A-264.848
    N590 X-4.154 A-265.401
    N592 X-4.1509 A-265.908
    N594 X-4.147 A-266.36
    N596 X-4.1421 Z.525 A-266.743
    N598 X-4.1366 A-267.051
    N600 X-4.131 A-267.242
    N602 X-4.1249 A-267.306
    N604 X-4.1189 A-267.238
    N606 X4.129 Z.5128 A-102.278
    N608 X4.1354 A-102.092
    N610 X4.1413 A-101.803
    N612 X4.1463 A-101.424
    N614 X4.1505 A-100.973
    N616 X4.1536 A-100.468
    N618 X4.1556 A-99.927
    N620 X4.1561 A-99.625
    N622 X4.1563 A-99.321
    N624 Z.5126 A-88.218
    N626 X4.1558 A-87.647
    N628 X4.154 A-87.097
    N630 X4.1509 A-86.592
    N632 X4.147 A-86.141
    N634 X4.1421 Z.5125 A-85.757
    N636 X4.1366 A-85.449
    N638 X4.131 A-85.259
    N640 X4.125 A-85.194
    N642 X4.119 A-85.262
    N644 X-4.129 Z.5003 A-250.223
    N646 X-4.1354 A-250.408
    N648 X-4.1413 A-250.698
    N650 X-4.1463 A-251.076
    N652 X-4.1505 A-251.527
    N654 X-4.1536 A-252.033
    N656 X-4.1556 A-252.573
    N658 X-4.1561 A-252.875
    N660 X-4.1563 A-253.179
    N662 Z.5001 A-264.281
    N664 X-4.1558 A-264.848
    N666 X-4.154 A-265.401
    N668 X-4.1509 A-265.908
    N670 X-4.147 A-266.36
    N672 X-4.1421 Z.5 A-266.743
    N674 X-4.1366 A-267.051
    N676 X-4.131 A-267.242
    N678 X-4.1249 A-267.306
    N680 X-4.1189 A-267.238
    N682 X4.129 Z.4878 A-102.278
    N684 X4.1354 A-102.092
    N686 X4.1413 A-101.803
    N688 X4.1463 A-101.424
    N690 X4.1505 A-100.973
    N692 X4.1536 A-100.468
    N694 X4.1556 A-99.927
    N696 X4.1561 A-99.625
    N698 X4.1563 A-99.321
    N700 Z.4876 A-88.218
    N702 X4.1558 A-87.647
    N704 X4.154 A-87.097
    N706 X4.1509 A-86.592
    N708 X4.147 A-86.141
    N710 X4.1421 Z.4875 A-85.757
    N712 X4.1366 A-85.449
    N714 X4.131 A-85.259
    N716 X4.125 A-85.194
    N718 X4.119 A-85.262
    N720 X-4.129 Z.4753 A-250.223
    N722 X-4.1354 A-250.408
    N724 X-4.1413 A-250.698
    N726 X-4.1463 A-251.076
    N728 X-4.1505 A-251.527
    N730 X-4.1536 A-252.033
    N732 X-4.1556 A-252.573
    N734 X-4.1561 A-252.875
    N736 X-4.1563 A-253.179
    N738 Z.4751 A-264.281
    N740 X-4.1558 A-264.848
    N742 X-4.154 A-265.401
    N744 X-4.1509 A-265.908
    N746 X-4.147 A-266.36
    N748 X-4.1421 Z.475 A-266.743
    N750 X-4.1366 A-267.051
    N752 X-4.131 A-267.242
    N754 X-4.1249 A-267.306
    N756 X-4.1189 A-267.238
    N758 X4.129 Z.4628 A-102.278
    N760 X4.1354 A-102.092
    N762 X4.1413 A-101.803
    N764 X4.1463 A-101.424
    N766 X4.1505 A-100.973
    N768 X4.1536 A-100.468
    N770 X4.1556 A-99.927
    N772 X4.1561 A-99.625
    N774 X4.1563 A-99.321
    N776 Z.4626 A-88.218
    N778 X4.1558 A-87.647
    N780 X4.154 A-87.097
    N782 X4.1509 A-86.592
    N784 X4.147 A-86.141
    N786 X4.1421 Z.4625 A-85.757
    N788 X4.1366 A-85.449
    N790 X4.131 A-85.259
    N792 X4.125 A-85.194
    N794 X4.119 A-85.262
    N796 X-4.129 Z.4503 A-250.223
    N798 X-4.1354 A-250.408
    N800 X-4.1413 A-250.698
    N802 X-4.1463 A-251.076
    N804 X-4.1505 A-251.527
    N806 X-4.1536 A-252.033
    N808 X-4.1556 A-252.573
    N810 X-4.1561 A-252.875
    N812 X-4.1563 A-253.179
    N814 Z.4501 A-264.281
    N816 X-4.1558 A-264.848
    N818 X-4.154 A-265.401
    N820 X-4.1509 A-265.908
    N822 X-4.147 A-266.36
    N824 X-4.1421 Z.45 A-266.743
    N826 X-4.1366 A-267.051
    N828 X-4.131 A-267.242
    N830 X-4.1249 A-267.306
    N832 X-4.1189 A-267.238
    N834 X4.129 Z.4378 A-102.278
    N836 X4.1354 A-102.092
    N838 X4.1413 A-101.803
    N840 X4.1463 A-101.424
    N842 X4.1505 A-100.973
    N844 X4.1536 A-100.468
    N846 X4.1556 A-99.927
    N848 X4.1561 A-99.625
    N850 X4.1563 A-99.321
    N852 Z.4376 A-88.218
    N854 X4.1558 A-87.647
    N856 X4.154 A-87.097
    N858 X4.1509 A-86.592
    N860 X4.147 A-86.141
    N862 X4.1421 Z.4375 A-85.757
    N864 X4.1366 A-85.449
    N866 X4.131 A-85.259
    N868 X4.125 A-85.194
    N870 X4.119 A-85.262
    N872 X-4.129 Z.4253 A-250.223
    N874 X-4.1354 A-250.408
    N876 X-4.1413 A-250.698
    N878 X-4.1463 A-251.076
    N880 X-4.1505 A-251.527
    N882 X-4.1536 A-252.033
    N884 X-4.1556 A-252.573
    N886 X-4.1561 A-252.875
    N888 X-4.1563 A-253.179
    N890 Z.4251 A-264.281
    N892 X-4.1558 A-264.848
    N894 X-4.154 A-265.401
    N896 X-4.1509 A-265.908
    N898 X-4.147 A-266.36
    N900 X-4.1421 Z.425 A-266.743
    N902 X-4.1366 A-267.051
    N904 X-4.131 A-267.242
    N906 X-4.1249 A-267.306
    N908 X-4.1189 A-267.238
    N910 X4.129 Z.4128 A-102.278
    N912 X4.1354 A-102.092
    N914 X4.1413 A-101.803
    N916 X4.1463 A-101.424
    N918 X4.1505 A-100.973
    N920 X4.1536 A-100.468
    N922 X4.1556 A-99.927
    N924 X4.1561 A-99.625
    N926 X4.1563 A-99.321
    N928 Z.4126 A-88.218
    N930 X4.1558 A-87.647
    N932 X4.154 A-87.097
    N934 X4.1509 A-86.592
    N936 X4.147 A-86.141
    N938 X4.1421 Z.4125 A-85.757
    N940 X4.1366 A-85.449
    N942 X4.131 A-85.259
    N944 X4.125 A-85.194
    N946 X4.119 A-85.262
    N948 X-4.129 A-250.223
    N950 X-4.1377 A-250.523
    N952 X-4.1453 A-250.996
    N954 X-4.1511 A-251.615
    N956 X-4.1549 A-252.333
    N958 X-4.156 A-252.751
    N960 X-4.1563 A-253.179
    N962 A-264.281
    N964 X-4.1552 A-265.077
    N966 X-4.1516 A-265.825
    N968 X-4.1458 A-266.468
    N970 X-4.1382 A-266.962
    N972 X-4.1293 A-267.27
    N974 X-4.1241 A-267.304
    N976 X-4.1189 A-267.238
    N978 X4.129 A-102.278
    N980 X4.1377 A-101.977
    N982 X4.1453 A-101.504
    N984 X4.1511 A-100.886
    N986 X4.1549 A-100.167
    N988 X4.156 A-99.749
    N990 X4.1563 A-99.321
    N992 A-88.218
    N994 X4.1552 A-87.417
    N996 X4.1516 A-86.671
    N998 X4.1458 A-86.03
    N1000 X4.1382 A-85.537
    N1002 X4.1293 A-85.23
    N1004 X4.1241 A-85.196
    N1006 X4.119 A-85.262
    N1008 G0 Z1.6875
    N1010 A-175.262
    N1012 Z.7875
    N1014 G1 Z.6875 F5.
    N1016 X-4.1337 Z.6753 A-340.338 F100.
    N1018 X-4.1397 A-340.608
    N1020 X-4.1449 A-340.962
    N1022 X-4.1493 A-341.391
    N1024 X-4.1528 A-341.887
    N1026 X-4.1552 A-342.43
    N1028 X-4.1562 A-342.997
    N1030 X-4.1563 A-343.179
    N1032 Z.6751 A-354.281
    N1034 X-4.1558 A-354.852
    N1036 X-4.154 A-355.401
    N1038 X-4.1509 A-355.908
    N1040 X-4.147 A-356.359
    N1042 X-4.1422 Z.675 A-356.743
    N1044 X-4.1366 A-357.051
    N1046 X-4.131 A-357.241
    N1048 X-4.1249 A-357.304
    N1050 X-4.1189 A-357.238
    N1052 X4.129 Z.6628 A-192.278
    N1054 X4.1354 A-192.098
    N1056 X4.1413 A-191.808
    N1058 X4.1463 A-191.424
    N1060 X4.1504 A-190.973
    N1062 X4.1536 A-190.471
    N1064 X4.1556 A-189.927
    N1066 X4.1561 A-189.628
    N1068 X4.1563 A-189.321
    N1070 Z.6626 A-178.218
    N1072 X4.1558 A-177.651
    N1074 X4.154 A-177.099
    N1076 X4.1509 A-176.592
    N1078 X4.147 A-176.139
    N1080 X4.1421 Z.6625 A-175.755
    N1082 X4.1366 A-175.449
    N1084 X4.131 A-175.257
    N1086 X4.125 A-175.192
    N1088 X4.119 A-175.262
    N1090 X-4.129 Z.6503 A-340.223
    N1092 X-4.1354 A-340.406
    N1094 X-4.1413 A-340.696
    N1096 X-4.1463 A-341.076
    N1098 X-4.1505 A-341.525
    N1100 X-4.1536 A-342.031
    N1102 X-4.1556 A-342.573
    N1104 X-4.1561 A-342.877
    N1106 X-4.1563 A-343.179
    N1108 Z.6501 A-354.281
    N1110 X-4.1558 A-354.852
    N1112 X-4.154 A-355.401
    N1114 X-4.1509 A-355.908
    N1116 X-4.147 A-356.359
    N1118 X-4.1422 Z.65 A-356.743
    N1120 X-4.1366 A-357.051
    N1122 X-4.131 A-357.241
    N1124 X-4.1249 A-357.304
    N1126 X-4.1189 A-357.238
    N1128 X4.129 Z.6378 A-192.278
    N1130 X4.1354 A-192.098
    N1132 X4.1413 A-191.808
    N1134 X4.1463 A-191.424
    N1136 X4.1504 A-190.973
    N1138 X4.1536 A-190.471
    N1140 X4.1556 A-189.927
    N1142 X4.1561 A-189.628
    N1144 X4.1563 A-189.321
    N1146 Z.6376 A-178.218
    N1148 X4.1558 A-177.651
    N1150 X4.154 A-177.099
    N1152 X4.1509 A-176.592
    N1154 X4.147 A-176.139
    N1156 X4.1421 Z.6375 A-175.755
    N1158 X4.1366 A-175.449
    N1160 X4.131 A-175.257
    N1162 X4.125 A-175.192
    N1164 X4.119 A-175.262
    N1166 X-4.129 Z.6253 A-340.223
    N1168 X-4.1354 A-340.406
    N1170 X-4.1413 A-340.696
    N1172 X-4.1463 A-341.076
    N1174 X-4.1505 A-341.525
    N1176 X-4.1536 A-342.031
    N1178 X-4.1556 A-342.573
    N1180 X-4.1561 A-342.877
    N1182 X-4.1563 A-343.179
    N1184 Z.6251 A-354.281
    N1186 X-4.1558 A-354.852
    N1188 X-4.154 A-355.401
    N1190 X-4.1509 A-355.908
    N1192 X-4.147 A-356.359
    N1194 X-4.1422 Z.625 A-356.743
    N1196 X-4.1366 A-357.051
    N1198 X-4.131 A-357.241
    N1200 X-4.1249 A-357.304
    N1202 X-4.1189 A-357.238
    N1204 X4.129 Z.6128 A-192.278
    N1206 X4.1354 A-192.098
    N1208 X4.1413 A-191.808
    N1210 X4.1463 A-191.424
    N1212 X4.1504 A-190.973
    N1214 X4.1536 A-190.471
    N1216 X4.1556 A-189.927
    N1218 X4.1561 A-189.628
    N1220 X4.1563 A-189.321
    N1222 Z.6126 A-178.218
    N1224 X4.1558 A-177.651
    N1226 X4.154 A-177.099
    N1228 X4.1509 A-176.592
    N1230 X4.147 A-176.139
    N1232 X4.1421 Z.6125 A-175.755
    N1234 X4.1366 A-175.449
    N1236 X4.131 A-175.257
    N1238 X4.125 A-175.192
    N1240 X4.119 A-175.262
    N1242 X-4.129 Z.6003 A-340.223
    N1244 X-4.1354 A-340.406
    N1246 X-4.1413 A-340.696
    N1248 X-4.1463 A-341.076
    N1250 X-4.1505 A-341.525
    N1252 X-4.1536 A-342.031
    N1254 X-4.1556 A-342.573
    N1256 X-4.1561 A-342.877
    N1258 X-4.1563 A-343.179
    N1260 Z.6001 A-354.281
    N1262 X-4.1558 A-354.852
    N1264 X-4.154 A-355.401
    N1266 X-4.1509 A-355.908
    N1268 X-4.147 A-356.359
    N1270 X-4.1422 Z.6 A-356.743
    N1272 X-4.1366 A-357.051
    N1274 X-4.131 A-357.241
    N1276 X-4.1249 A-357.304
    N1278 X-4.1189 A-357.238
    N1280 X4.129 Z.5878 A-192.278
    N1282 X4.1354 A-192.098
    N1284 X4.1413 A-191.808
    N1286 X4.1463 A-191.424
    N1288 X4.1504 A-190.973
    N1290 X4.1536 A-190.471
    N1292 X4.1556 A-189.927
    N1294 X4.1561 A-189.628
    N1296 X4.1563 A-189.321
    N1298 Z.5876 A-178.218
    N1300 X4.1558 A-177.651
    N1302 X4.154 A-177.099
    N1304 X4.1509 A-176.592
    N1306 X4.147 A-176.139
    N1308 X4.1421 Z.5875 A-175.755
    N1310 X4.1366 A-175.449
    N1312 X4.131 A-175.257
    N1314 X4.125 A-175.192
    N1316 X4.119 A-175.262
    N1318 X-4.129 Z.5753 A-340.223
    N1320 X-4.1354 A-340.406
    N1322 X-4.1413 A-340.696
    N1324 X-4.1463 A-341.076
    N1326 X-4.1505 A-341.525
    N1328 X-4.1536 A-342.031
    N1330 X-4.1556 A-342.573
    N1332 X-4.1561 A-342.877
    N1334 X-4.1563 A-343.179
    N1336 Z.5751 A-354.281
    N1338 X-4.1558 A-354.852
    N1340 X-4.154 A-355.401
    N1342 X-4.1509 A-355.908
    N1344 X-4.147 A-356.359
    N1346 X-4.1422 Z.575 A-356.743
    N1348 X-4.1366 A-357.051
    N1350 X-4.131 A-357.241
    N1352 X-4.1249 A-357.304
    N1354 X-4.1189 A-357.238
    N1356 X4.129 Z.5628 A-192.278
    N1358 X4.1354 A-192.098
    N1360 X4.1413 A-191.808
    N1362 X4.1463 A-191.424
    N1364 X4.1504 A-190.973
    N1366 X4.1536 A-190.471
    N1368 X4.1556 A-189.927
    N1370 X4.1561 A-189.628
    N1372 X4.1563 A-189.321
    N1374 Z.5626 A-178.218
    N1376 X4.1558 A-177.651
    N1378 X4.154 A-177.099
    N1380 X4.1509 A-176.592
    N1382 X4.147 A-176.139
    N1384 X4.1421 Z.5625 A-175.755
    N1386 X4.1366 A-175.449
    N1388 X4.131 A-175.257
    N1390 X4.125 A-175.192
    N1392 X4.119 A-175.262
    N1394 X-4.129 Z.5503 A-340.223
    N1396 X-4.1354 A-340.406
    N1398 X-4.1413 A-340.696
    N1400 X-4.1463 A-341.076
    N1402 X-4.1505 A-341.525
    N1404 X-4.1536 A-342.031
    N1406 X-4.1556 A-342.573
    N1408 X-4.1561 A-342.877
    N1410 X-4.1563 A-343.179
    N1412 Z.5501 A-354.281
    N1414 X-4.1558 A-354.852
    N1416 X-4.154 A-355.401
    N1418 X-4.1509 A-355.908
    N1420 X-4.147 A-356.359
    N1422 X-4.1422 Z.55 A-356.743
    N1424 X-4.1366 A-357.051
    N1426 X-4.131 A-357.241
    N1428 X-4.1249 A-357.304
    N1430 X-4.1189 A-357.238
    N1432 X4.129 Z.5378 A-192.278
    N1434 X4.1354 A-192.098
    N1436 X4.1413 A-191.808
    N1438 X4.1463 A-191.424
    N1440 X4.1504 A-190.973
    N1442 X4.1536 A-190.471
    N1444 X4.1556 A-189.927
    N1446 X4.1561 A-189.628
    N1448 X4.1563 A-189.321
    N1450 Z.5376 A-178.218
    N1452 X4.1558 A-177.651
    N1454 X4.154 A-177.099
    N1456 X4.1509 A-176.592
    N1458 X4.147 A-176.139
    N1460 X4.1421 Z.5375 A-175.755
    N1462 X4.1366 A-175.449
    N1464 X4.131 A-175.257
    N1466 X4.125 A-175.192
    N1468 X4.119 A-175.262
    N1470 X-4.129 Z.5253 A-340.223
    N1472 X-4.1354 A-340.406
    N1474 X-4.1413 A-340.696
    N1476 X-4.1463 A-341.076
    N1478 X-4.1505 A-341.525
    N1480 X-4.1536 A-342.031
    N1482 X-4.1556 A-342.573
    N1484 X-4.1561 A-342.877
    N1486 X-4.1563 A-343.179
    N1488 Z.5251 A-354.281
    N1490 X-4.1558 A-354.852
    N1492 X-4.154 A-355.401
    N1494 X-4.1509 A-355.908
    N1496 X-4.147 A-356.359
    N1498 X-4.1422 Z.525 A-356.743
    N1500 X-4.1366 A-357.051
    N1502 X-4.131 A-357.241
    N1504 X-4.1249 A-357.304
    N1506 X-4.1189 A-357.238
    N1508 X4.129 Z.5128 A-192.278
    N1510 X4.1354 A-192.098
    N1512 X4.1413 A-191.808
    N1514 X4.1463 A-191.424
    N1516 X4.1504 A-190.973
    N1518 X4.1536 A-190.471
    N1520 X4.1556 A-189.927
    N1522 X4.1561 A-189.628
    N1524 X4.1563 A-189.321
    N1526 Z.5126 A-178.218
    N1528 X4.1558 A-177.651
    N1530 X4.154 A-177.099
    N1532 X4.1509 A-176.592
    N1534 X4.147 A-176.139
    N1536 X4.1421 Z.5125 A-175.755
    N1538 X4.1366 A-175.449
    N1540 X4.131 A-175.257
    N1542 X4.125 A-175.192
    N1544 X4.119 A-175.262
    N1546 X-4.129 Z.5003 A-340.223
    N1548 X-4.1354 A-340.406
    N1550 X-4.1413 A-340.696
    N1552 X-4.1463 A-341.076
    N1554 X-4.1505 A-341.525
    N1556 X-4.1536 A-342.031
    N1558 X-4.1556 A-342.573
    N1560 X-4.1561 A-342.877
    N1562 X-4.1563 A-343.179
    N1564 Z.5001 A-354.281
    N1566 X-4.1558 A-354.852
    N1568 X-4.154 A-355.401
    N1570 X-4.1509 A-355.908
    N1572 X-4.147 A-356.359
    N1574 X-4.1422 Z.5 A-356.743
    N1576 X-4.1366 A-357.051
    N1578 X-4.131 A-357.241
    N1580 X-4.1249 A-357.304
    N1582 X-4.1189 A-357.238
    N1584 X4.129 Z.4878 A-192.278
    N1586 X4.1354 A-192.098
    N1588 X4.1413 A-191.808
    N1590 X4.1463 A-191.424
    N1592 X4.1504 A-190.973
    N1594 X4.1536 A-190.471
    N1596 X4.1556 A-189.927
    N1598 X4.1561 A-189.628
    N1600 X4.1563 A-189.321
    N1602 Z.4876 A-178.218
    N1604 X4.1558 A-177.651
    N1606 X4.154 A-177.099
    N1608 X4.1509 A-176.592
    N1610 X4.147 A-176.139
    N1612 X4.1421 Z.4875 A-175.755
    N1614 X4.1366 A-175.449
    N1616 X4.131 A-175.257
    N1618 X4.125 A-175.192
    N1620 X4.119 A-175.262
    N1622 X-4.129 Z.4753 A-340.223
    N1624 X-4.1354 A-340.406
    N1626 X-4.1413 A-340.696
    N1628 X-4.1463 A-341.076
    N1630 X-4.1505 A-341.525
    N1632 X-4.1536 A-342.031
    N1634 X-4.1556 A-342.573
    N1636 X-4.1561 A-342.877
    N1638 X-4.1563 A-343.179
    N1640 Z.4751 A-354.281
    N1642 X-4.1558 A-354.852
    N1644 X-4.154 A-355.401
    N1646 X-4.1509 A-355.908
    N1648 X-4.147 A-356.359
    N1650 X-4.1422 Z.475 A-356.743
    N1652 X-4.1366 A-357.051
    N1654 X-4.131 A-357.241
    N1656 X-4.1249 A-357.304
    N1658 X-4.1189 A-357.238
    N1660 X4.129 Z.4628 A-192.278
    N1662 X4.1354 A-192.098
    N1664 X4.1413 A-191.808
    N1666 X4.1463 A-191.424
    N1668 X4.1504 A-190.973
    N1670 X4.1536 A-190.471
    N1672 X4.1556 A-189.927
    N1674 X4.1561 A-189.628
    N1676 X4.1563 A-189.321
    N1678 Z.4626 A-178.218
    N1680 X4.1558 A-177.651
    N1682 X4.154 A-177.099
    N1684 X4.1509 A-176.592
    N1686 X4.147 A-176.139
    N1688 X4.1421 Z.4625 A-175.755
    N1690 X4.1366 A-175.449
    N1692 X4.131 A-175.257
    N1694 X4.125 A-175.192
    N1696 X4.119 A-175.262
    N1698 X-4.129 Z.4503 A-340.223
    N1700 X-4.1354 A-340.406
    N1702 X-4.1413 A-340.696
    N1704 X-4.1463 A-341.076
    N1706 X-4.1505 A-341.525
    N1708 X-4.1536 A-342.031
    N1710 X-4.1556 A-342.573
    N1712 X-4.1561 A-342.877
    N1714 X-4.1563 A-343.179
    N1716 Z.4501 A-354.281
    N1718 X-4.1558 A-354.852
    N1720 X-4.154 A-355.401
    N1722 X-4.1509 A-355.908
    N1724 X-4.147 A-356.359
    N1726 X-4.1422 Z.45 A-356.743
    N1728 X-4.1366 A-357.051
    N1730 X-4.131 A-357.241
    N1732 X-4.1249 A-357.304
    N1734 X-4.1189 A-357.238
    N1736 X4.129 Z.4378 A-192.278
    N1738 X4.1354 A-192.098
    N1740 X4.1413 A-191.808
    N1742 X4.1463 A-191.424
    N1744 X4.1504 A-190.973
    N1746 X4.1536 A-190.471
    N1748 X4.1556 A-189.927
    N1750 X4.1561 A-189.628
    N1752 X4.1563 A-189.321
    N1754 Z.4376 A-178.218
    N1756 X4.1558 A-177.651
    N1758 X4.154 A-177.099
    N1760 X4.1509 A-176.592
    N1762 X4.147 A-176.139
    N1764 X4.1421 Z.4375 A-175.755
    N1766 X4.1366 A-175.449
    N1768 X4.131 A-175.257
    N1770 X4.125 A-175.192
    N1772 X4.119 A-175.262
    N1774 X-4.129 Z.4253 A-340.223
    N1776 X-4.1354 A-340.406
    N1778 X-4.1413 A-340.696
    N1780 X-4.1463 A-341.076
    N1782 X-4.1505 A-341.525
    N1784 X-4.1536 A-342.031
    N1786 X-4.1556 A-342.573
    N1788 X-4.1561 A-342.877
    N1790 X-4.1563 A-343.179
    N1792 Z.4251 A-354.281
    N1794 X-4.1558 A-354.852
    N1796 X-4.154 A-355.401
    N1798 X-4.1509 A-355.908
    N1800 X-4.147 A-356.359
    N1802 X-4.1422 Z.425 A-356.743
    N1804 X-4.1366 A-357.051
    N1806 X-4.131 A-357.241
    N1808 X-4.1249 A-357.304
    N1810 X-4.1189 A-357.238
    N1812 X4.129 Z.4128 A-192.278
    N1814 X4.1354 A-192.098
    N1816 X4.1413 A-191.808
    N1818 X4.1463 A-191.424
    N1820 X4.1504 A-190.973
    N1822 X4.1536 A-190.471
    N1824 X4.1556 A-189.927
    N1826 X4.1561 A-189.628
    N1828 X4.1563 A-189.321
    N1830 Z.4126 A-178.218
    N1832 X4.1558 A-177.651
    N1834 X4.154 A-177.099
    N1836 X4.1509 A-176.592
    N1838 X4.147 A-176.139
    N1840 X4.1421 Z.4125 A-175.755
    N1842 X4.1366 A-175.449
    N1844 X4.131 A-175.257
    N1846 X4.125 A-175.192
    N1848 X4.119 A-175.262
    N1850 X-4.129 A-340.223
    N1852 X-4.1377 A-340.521
    N1854 X-4.1453 A-340.995
    N1856 X-4.1511 A-341.613
    N1858 X-4.1549 A-342.333
    N1860 X-4.156 A-342.753
    N1862 X-4.1563 A-343.179
    N1864 A-354.281
    N1866 X-4.1552 A-355.081
    N1868 X-4.1516 A-355.827
    N1870 X-4.1458 A-356.468
    N1872 X-4.1382 A-356.961
    N1874 X-4.1293 A-357.27
    N1876 X-4.1241 A-357.302
    N1878 X-4.1189 A-357.238
    N1880 X4.129 A-192.278
    N1882 X4.1378 A-191.983
    N1884 X4.1453 A-191.509
    N1886 X4.1512 A-190.888
    N1888 X4.1549 A-190.167
    N1890 X4.156 A-189.747
    N1892 X4.1563 A-189.321
    N1894 A-178.218
    N1896 X4.1552 A-177.422
    N1898 X4.1516 A-176.674
    N1900 X4.1458 A-176.03
    N1902 X4.1382 A-175.536
    N1904 X4.1293 A-175.23
    N1906 X4.1241 A-175.194
    N1908 X4.119 A-175.262
    N1910 G0 Z1.6875
    N1912 A-265.262
    N1914 Z.7875
    N1916 G1 Z.6875 F5.
    N1918 X-4.1337 Z.6753 A-430.338 F100.
    N1920 X-4.1397 A-430.605
    N1922 X-4.1449 A-430.959
    N1924 X-4.1493 A-431.391
    N1926 X-4.1528 A-431.885
    N1928 X-4.1552 A-432.428
    N1930 X-4.1562 A-432.997
    N1932 X-4.1563 A-433.179
    N1934 Z.6751 A-444.281
    N1936 X-4.1558 A-444.85
    N1938 X-4.154 A-445.4
    N1940 X-4.1509 A-445.908
    N1942 X-4.147 A-446.357
    N1944 X-4.1422 Z.675 A-446.741
    N1946 X-4.1366 A-447.051
    N1948 X-4.131 A-447.239
    N1950 X-4.1249 A-447.303
    N1952 X-4.1189 A-447.238
    N1954 X4.129 Z.6628 A-282.278
    N1956 X4.1354 A-282.096
    N1958 X4.1413 A-281.805
    N1960 X4.1463 A-281.424
    N1962 X4.1504 A-280.972
    N1964 X4.1536 A-280.469
    N1966 X4.1556 A-279.927
    N1968 X4.1561 A-279.626
    N1970 X4.1563 A-279.321
    N1972 Z.6626 A-268.218
    N1974 X4.1558 A-267.651
    N1976 X4.154 A-267.102
    N1978 X4.1509 A-266.592
    N1980 X4.147 A-266.144
    N1982 X4.1422 Z.6625 A-265.76
    N1984 X4.1366 A-265.449
    N1986 X4.131 A-265.263
    N1988 X4.125 A-265.198
    N1990 X4.119 A-265.262
    N1992 X-4.129 Z.6503 A-430.223
    N1994 X-4.1354 A-430.405
    N1996 X-4.1413 A-430.694
    N1998 X-4.1463 A-431.076
    N2000 X-4.1505 A-431.523
    N2002 X-4.1536 A-432.028
    N2004 X-4.1556 A-432.573
    N2006 X-4.1561 A-432.875
    N2008 X-4.1563 A-433.179
    N2010 Z.6501 A-444.281
    N2012 X-4.1558 A-444.85
    N2014 X-4.154 A-445.4
    N2016 X-4.1509 A-445.908
    N2018 X-4.147 A-446.357
    N2020 X-4.1422 Z.65 A-446.741
    N2022 X-4.1366 A-447.051
    N2024 X-4.131 A-447.239
    N2026 X-4.1249 A-447.303
    N2028 X-4.1189 A-447.238
    N2030 X4.129 Z.6378 A-282.278
    N2032 X4.1354 A-282.096
    N2034 X4.1413 A-281.805
    N2036 X4.1463 A-281.424
    N2038 X4.1504 A-280.972
    N2040 X4.1536 A-280.469
    N2042 X4.1556 A-279.927
    N2044 X4.1561 A-279.626
    N2046 X4.1563 A-279.321
    N2048 Z.6376 A-268.218
    N2050 X4.1558 A-267.651
    N2052 X4.154 A-267.102
    N2054 X4.1509 A-266.592
    N2056 X4.147 A-266.144
    N2058 X4.1422 Z.6375 A-265.76
    N2060 X4.1366 A-265.449
    N2062 X4.131 A-265.263
    N2064 X4.125 A-265.198
    N2066 X4.119 A-265.262
    N2068 X-4.129 Z.6253 A-430.223
    N2070 X-4.1354 A-430.405
    N2072 X-4.1413 A-430.694
    N2074 X-4.1463 A-431.076
    N2076 X-4.1505 A-431.523
    N2078 X-4.1536 A-432.028
    N2080 X-4.1556 A-432.573
    N2082 X-4.1561 A-432.875
    N2084 X-4.1563 A-433.179
    N2086 Z.6251 A-444.281
    N2088 X-4.1558 A-444.85
    N2090 X-4.154 A-445.4
    N2092 X-4.1509 A-445.908
    N2094 X-4.147 A-446.357
    N2096 X-4.1422 Z.625 A-446.741
    N2098 X-4.1366 A-447.051
    N2100 X-4.131 A-447.239
    N2102 X-4.1249 A-447.303
    N2104 X-4.1189 A-447.238
    N2106 X4.129 Z.6128 A-282.278
    N2108 X4.1354 A-282.096
    N2110 X4.1413 A-281.805
    N2112 X4.1463 A-281.424
    N2114 X4.1504 A-280.972
    N2116 X4.1536 A-280.469
    N2118 X4.1556 A-279.927
    N2120 X4.1561 A-279.626
    N2122 X4.1563 A-279.321
    N2124 Z.6126 A-268.218
    N2126 X4.1558 A-267.651
    N2128 X4.154 A-267.102
    N2130 X4.1509 A-266.592
    N2132 X4.147 A-266.144
    N2134 X4.1422 Z.6125 A-265.76
    N2136 X4.1366 A-265.449
    N2138 X4.131 A-265.263
    N2140 X4.125 A-265.198
    N2142 X4.119 A-265.262
    N2144 X-4.129 Z.6003 A-430.223
    N2146 X-4.1354 A-430.405
    N2148 X-4.1413 A-430.694
    N2150 X-4.1463 A-431.076
    N2152 X-4.1505 A-431.523
    N2154 X-4.1536 A-432.028
    N2156 X-4.1556 A-432.573
    N2158 X-4.1561 A-432.875
    N2160 X-4.1563 A-433.179
    N2162 Z.6001 A-444.281
    N2164 X-4.1558 A-444.85
    N2166 X-4.154 A-445.4
    N2168 X-4.1509 A-445.908
    N2170 X-4.147 A-446.357
    N2172 X-4.1422 Z.6 A-446.741
    N2174 X-4.1366 A-447.051
    N2176 X-4.131 A-447.239
    N2178 X-4.1249 A-447.303
    N2180 X-4.1189 A-447.238
    N2182 X4.129 Z.5878 A-282.278
    N2184 X4.1354 A-282.096
    N2186 X4.1413 A-281.805
    N2188 X4.1463 A-281.424
    N2190 X4.1504 A-280.972
    N2192 X4.1536 A-280.469
    N2194 X4.1556 A-279.927
    N2196 X4.1561 A-279.626
    N2198 X4.1563 A-279.321
    N2200 Z.5876 A-268.218
    N2202 X4.1558 A-267.651
    N2204 X4.154 A-267.102
    N2206 X4.1509 A-266.592
    N2208 X4.147 A-266.144
    N2210 X4.1422 Z.5875 A-265.76
    N2212 X4.1366 A-265.449
    N2214 X4.131 A-265.263
    N2216 X4.125 A-265.198
    N2218 X4.119 A-265.262
    N2220 X-4.129 Z.5753 A-430.223
    N2222 X-4.1354 A-430.405
    N2224 X-4.1413 A-430.694
    N2226 X-4.1463 A-431.076
    N2228 X-4.1505 A-431.523
    N2230 X-4.1536 A-432.028
    N2232 X-4.1556 A-432.573
    N2234 X-4.1561 A-432.875
    N2236 X-4.1563 A-433.179
    N2238 Z.5751 A-444.281
    N2240 X-4.1558 A-444.85
    N2242 X-4.154 A-445.4
    N2244 X-4.1509 A-445.908
    N2246 X-4.147 A-446.357
    N2248 X-4.1422 Z.575 A-446.741
    N2250 X-4.1366 A-447.051
    N2252 X-4.131 A-447.239
    N2254 X-4.1249 A-447.303
    N2256 X-4.1189 A-447.238
    N2258 X4.129 Z.5628 A-282.278
    N2260 X4.1354 A-282.096
    N2262 X4.1413 A-281.805
    N2264 X4.1463 A-281.424
    N2266 X4.1504 A-280.972
    N2268 X4.1536 A-280.469
    N2270 X4.1556 A-279.927
    N2272 X4.1561 A-279.626
    N2274 X4.1563 A-279.321
    N2276 Z.5626 A-268.218
    N2278 X4.1558 A-267.651
    N2280 X4.154 A-267.102
    N2282 X4.1509 A-266.592
    N2284 X4.147 A-266.144
    N2286 X4.1422 Z.5625 A-265.76
    N2288 X4.1366 A-265.449
    N2290 X4.131 A-265.263
    N2292 X4.125 A-265.198
    N2294 X4.119 A-265.262
    N2296 X-4.129 Z.5503 A-430.223
    N2298 X-4.1354 A-430.405
    N2300 X-4.1413 A-430.694
    N2302 X-4.1463 A-431.076
    N2304 X-4.1505 A-431.523
    N2306 X-4.1536 A-432.028
    N2308 X-4.1556 A-432.573
    N2310 X-4.1561 A-432.875
    N2312 X-4.1563 A-433.179
    N2314 Z.5501 A-444.281
    N2316 X-4.1558 A-444.85
    N2318 X-4.154 A-445.4
    N2320 X-4.1509 A-445.908
    N2322 X-4.147 A-446.357
    N2324 X-4.1422 Z.55 A-446.741
    N2326 X-4.1366 A-447.051
    N2328 X-4.131 A-447.239
    N2330 X-4.1249 A-447.303
    N2332 X-4.1189 A-447.238
    N2334 X4.129 Z.5378 A-282.278
    N2336 X4.1354 A-282.096
    N2338 X4.1413 A-281.805
    N2340 X4.1463 A-281.424
    N2342 X4.1504 A-280.972
    N2344 X4.1536 A-280.469
    N2346 X4.1556 A-279.927
    N2348 X4.1561 A-279.626
    N2350 X4.1563 A-279.321
    N2352 Z.5376 A-268.218
    N2354 X4.1558 A-267.651
    N2356 X4.154 A-267.102
    N2358 X4.1509 A-266.592
    N2360 X4.147 A-266.144
    N2362 X4.1422 Z.5375 A-265.76
    N2364 X4.1366 A-265.449
    N2366 X4.131 A-265.263
    N2368 X4.125 A-265.198
    N2370 X4.119 A-265.262
    N2372 X-4.129 Z.5253 A-430.223
    N2374 X-4.1354 A-430.405
    N2376 X-4.1413 A-430.694
    N2378 X-4.1463 A-431.076
    N2380 X-4.1505 A-431.523
    N2382 X-4.1536 A-432.028
    N2384 X-4.1556 A-432.573
    N2386 X-4.1561 A-432.875
    N2388 X-4.1563 A-433.179
    N2390 Z.5251 A-444.281
    N2392 X-4.1558 A-444.85
    N2394 X-4.154 A-445.4
    N2396 X-4.1509 A-445.908
    N2398 X-4.147 A-446.357
    N2400 X-4.1422 Z.525 A-446.741
    N2402 X-4.1366 A-447.051
    N2404 X-4.131 A-447.239
    N2406 X-4.1249 A-447.303
    N2408 X-4.1189 A-447.238
    N2410 X4.129 Z.5128 A-282.278
    N2412 X4.1354 A-282.096
    N2414 X4.1413 A-281.805
    N2416 X4.1463 A-281.424
    N2418 X4.1504 A-280.972
    N2420 X4.1536 A-280.469
    N2422 X4.1556 A-279.927
    N2424 X4.1561 A-279.626
    N2426 X4.1563 A-279.321
    N2428 Z.5126 A-268.218
    N2430 X4.1558 A-267.651
    N2432 X4.154 A-267.102
    N2434 X4.1509 A-266.592
    N2436 X4.147 A-266.144
    N2438 X4.1422 Z.5125 A-265.76
    N2440 X4.1366 A-265.449
    N2442 X4.131 A-265.263
    N2444 X4.125 A-265.198
    N2446 X4.119 A-265.262
    N2448 X-4.129 Z.5003 A-430.223
    N2450 X-4.1354 A-430.405
    N2452 X-4.1413 A-430.694
    N2454 X-4.1463 A-431.076
    N2456 X-4.1505 A-431.523
    N2458 X-4.1536 A-432.028
    N2460 X-4.1556 A-432.573
    N2462 X-4.1561 A-432.875
    N2464 X-4.1563 A-433.179
    N2466 Z.5001 A-444.281
    N2468 X-4.1558 A-444.85
    N2470 X-4.154 A-445.4
    N2472 X-4.1509 A-445.908
    N2474 X-4.147 A-446.357
    N2476 X-4.1422 Z.5 A-446.741
    N2478 X-4.1366 A-447.051
    N2480 X-4.131 A-447.239
    N2482 X-4.1249 A-447.303
    N2484 X-4.1189 A-447.238
    N2486 X4.129 Z.4878 A-282.278
    N2488 X4.1354 A-282.096
    N2490 X4.1413 A-281.805
    N2492 X4.1463 A-281.424
    N2494 X4.1504 A-280.972
    N2496 X4.1536 A-280.469
    N2498 X4.1556 A-279.927
    N2500 X4.1561 A-279.626
    N2502 X4.1563 A-279.321
    N2504 Z.4876 A-268.218
    N2506 X4.1558 A-267.651
    N2508 X4.154 A-267.102
    N2510 X4.1509 A-266.592
    N2512 X4.147 A-266.144
    N2514 X4.1422 Z.4875 A-265.76
    N2516 X4.1366 A-265.449
    N2518 X4.131 A-265.263
    N2520 X4.125 A-265.198
    N2522 X4.119 A-265.262
    N2524 X-4.129 Z.4753 A-430.223
    N2526 X-4.1354 A-430.405
    N2528 X-4.1413 A-430.694
    N2530 X-4.1463 A-431.076
    N2532 X-4.1505 A-431.523
    N2534 X-4.1536 A-432.028
    N2536 X-4.1556 A-432.573
    N2538 X-4.1561 A-432.875
    N2540 X-4.1563 A-433.179
    N2542 Z.4751 A-444.281
    N2544 X-4.1558 A-444.85
    N2546 X-4.154 A-445.4
    N2548 X-4.1509 A-445.908
    N2550 X-4.147 A-446.357
    N2552 X-4.1422 Z.475 A-446.741
    N2554 X-4.1366 A-447.051
    N2556 X-4.131 A-447.239
    N2558 X-4.1249 A-447.303
    N2560 X-4.1189 A-447.238
    N2562 X4.129 Z.4628 A-282.278
    N2564 X4.1354 A-282.096
    N2566 X4.1413 A-281.805
    N2568 X4.1463 A-281.424
    N2570 X4.1504 A-280.972
    N2572 X4.1536 A-280.469
    N2574 X4.1556 A-279.927
    N2576 X4.1561 A-279.626
    N2578 X4.1563 A-279.321
    N2580 Z.4626 A-268.218
    N2582 X4.1558 A-267.651
    N2584 X4.154 A-267.102
    N2586 X4.1509 A-266.592
    N2588 X4.147 A-266.144
    N2590 X4.1422 Z.4625 A-265.76
    N2592 X4.1366 A-265.449
    N2594 X4.131 A-265.263
    N2596 X4.125 A-265.198
    N2598 X4.119 A-265.262
    N2600 X-4.129 Z.4503 A-430.223
    N2602 X-4.1354 A-430.405
    N2604 X-4.1413 A-430.694
    N2606 X-4.1463 A-431.076
    N2608 X-4.1505 A-431.523
    N2610 X-4.1536 A-432.028
    N2612 X-4.1556 A-432.573
    N2614 X-4.1561 A-432.875
    N2616 X-4.1563 A-433.179
    N2618 Z.4501 A-444.281
    N2620 X-4.1558 A-444.85
    N2622 X-4.154 A-445.4
    N2624 X-4.1509 A-445.908
    N2626 X-4.147 A-446.357
    N2628 X-4.1422 Z.45 A-446.741
    N2630 X-4.1366 A-447.051
    N2632 X-4.131 A-447.239
    N2634 X-4.1249 A-447.303
    N2636 X-4.1189 A-447.238
    N2638 X4.129 Z.4378 A-282.278
    N2640 X4.1354 A-282.096
    N2642 X4.1413 A-281.805
    N2644 X4.1463 A-281.424
    N2646 X4.1504 A-280.972
    N2648 X4.1536 A-280.469
    N2650 X4.1556 A-279.927
    N2652 X4.1561 A-279.626
    N2654 X4.1563 A-279.321
    N2656 Z.4376 A-268.218
    N2658 X4.1558 A-267.651
    N2660 X4.154 A-267.102
    N2662 X4.1509 A-266.592
    N2664 X4.147 A-266.144
    N2666 X4.1422 Z.4375 A-265.76
    N2668 X4.1366 A-265.449
    N2670 X4.131 A-265.263
    N2672 X4.125 A-265.198
    N2674 X4.119 A-265.262
    N2676 X-4.129 Z.4253 A-430.223
    N2678 X-4.1354 A-430.405
    N2680 X-4.1413 A-430.694
    N2682 X-4.1463 A-431.076
    N2684 X-4.1505 A-431.523
    N2686 X-4.1536 A-432.028
    N2688 X-4.1556 A-432.573
    N2690 X-4.1561 A-432.875
    N2692 X-4.1563 A-433.179
    N2694 Z.4251 A-444.281
    N2696 X-4.1558 A-444.85
    N2698 X-4.154 A-445.4
    N2700 X-4.1509 A-445.908
    N2702 X-4.147 A-446.357
    N2704 X-4.1422 Z.425 A-446.741
    N2706 X-4.1366 A-447.051
    N2708 X-4.131 A-447.239
    N2710 X-4.1249 A-447.303
    N2712 X-4.1189 A-447.238
    N2714 X4.129 Z.4128 A-282.278
    N2716 X4.1354 A-282.096
    N2718 X4.1413 A-281.805
    N2720 X4.1463 A-281.424
    N2722 X4.1504 A-280.972
    N2724 X4.1536 A-280.469
    N2726 X4.1556 A-279.927
    N2728 X4.1561 A-279.626
    N2730 X4.1563 A-279.321
    N2732 Z.4126 A-268.218
    N2734 X4.1558 A-267.651
    N2736 X4.154 A-267.102
    N2738 X4.1509 A-266.592
    N2740 X4.147 A-266.144
    N2742 X4.1422 Z.4125 A-265.76
    N2744 X4.1366 A-265.449
    N2746 X4.131 A-265.263
    N2748 X4.125 A-265.198
    N2750 X4.119 A-265.262
    N2752 X-4.129 A-430.223
    N2754 X-4.1377 A-430.519
    N2756 X-4.1453 A-430.992
    N2758 X-4.1511 A-431.61
    N2760 X-4.1549 A-432.333
    N2762 X-4.156 A-432.751
    N2764 X-4.1563 A-433.179
    N2766 A-444.281
    N2768 X-4.1552 A-445.081
    N2770 X-4.1516 A-445.829
    N2772 X-4.1458 A-446.473
    N2774 X-4.1382 A-446.967
    N2776 X-4.1293 A-447.27
    N2778 X-4.1241 A-447.309
    N2780 X-4.1189 A-447.238
    N2782 X4.129 A-282.278
    N2784 X4.1377 A-281.982
    N2786 X4.1453 A-281.509
    N2788 X4.1511 A-280.892
    N2790 X4.1549 A-280.167
    N2792 X4.156 A-279.75
    N2794 X4.1563 A-279.321
    N2796 A-268.218
    N2798 X4.1552 A-267.42
    N2800 X4.1516 A-266.672
    N2802 X4.1458 A-266.028
    N2804 X4.1382 A-265.534
    N2806 X4.1293 A-265.23
    N2808 X4.1241 A-265.192
    N2810 X4.119 A-265.262
    N2812 G0 Z1.6875
    N2814 A4.738
    N2816 Z.7875
    N2818 G1 Z.6875 F5.
    N2820 X-4.1337 Z.6753 A-160.338 F100.
    N2822 X-4.1397 A-160.603
    N2824 X-4.1449 A-160.957
    N2826 X-4.1493 A-161.391
    N2828 X-4.1528 A-161.882
    N2830 X-4.1552 A-162.425
    N2832 X-4.1562 A-162.997
    N2834 X-4.1563 A-163.179
    N2836 Z.6751 A-174.281
    N2838 X-4.1558 A-174.85
    N2840 X-4.154 A-175.401
    N2842 X-4.1509 A-175.908
    N2844 X-4.147 A-176.362
    N2846 X-4.1421 Z.675 A-176.745
    N2848 X-4.1366 A-177.051
    N2850 X-4.131 A-177.244
    N2852 X-4.1249 A-177.308
    N2854 X-4.1189 A-177.238
    N2856 X4.129 Z.6628 A-12.278
    N2858 X4.1354 A-12.094
    N2860 X4.1413 A-11.805
    N2862 X4.1463 A-11.424
    N2864 X4.1505 A-10.975
    N2866 X4.1536 A-10.47
    N2868 X4.1556 A-9.927
    N2870 X4.1561 A-9.623
    N2872 X4.1563 A-9.321
    N2874 Z.6626 A1.782
    N2876 X4.1558 A2.352
    N2878 X4.154 A2.901
    N2880 X4.1509 A3.408
    N2882 X4.147 A3.858
    N2884 X4.1422 Z.6625 A4.243
    N2886 X4.1366 A4.551
    N2888 X4.131 A4.74
    N2890 X4.125 A4.805
    N2892 X4.119 A4.738
    N2894 X-4.129 Z.6503 A-160.223
    N2896 X-4.1354 A-160.402
    N2898 X-4.1413 A-160.693
    N2900 X-4.1463 A-161.076
    N2902 X-4.1504 A-161.527
    N2904 X-4.1536 A-162.029
    N2906 X-4.1556 A-162.573
    N2908 X-4.1561 A-162.873
    N2910 X-4.1563 A-163.179
    N2912 Z.6501 A-174.281
    N2914 X-4.1558 A-174.85
    N2916 X-4.154 A-175.401
    N2918 X-4.1509 A-175.908
    N2920 X-4.147 A-176.362
    N2922 X-4.1421 Z.65 A-176.745
    N2924 X-4.1366 A-177.051
    N2926 X-4.131 A-177.244
    N2928 X-4.1249 A-177.308
    N2930 X-4.1189 A-177.238
    N2932 X4.129 Z.6378 A-12.278
    N2934 X4.1354 A-12.094
    N2936 X4.1413 A-11.805
    N2938 X4.1463 A-11.424
    N2940 X4.1505 A-10.975
    N2942 X4.1536 A-10.47
    N2944 X4.1556 A-9.927
    N2946 X4.1561 A-9.623
    N2948 X4.1563 A-9.321
    N2950 Z.6376 A1.782
    N2952 X4.1558 A2.352
    N2954 X4.154 A2.901
    N2956 X4.1509 A3.408
    N2958 X4.147 A3.858
    N2960 X4.1422 Z.6375 A4.243
    N2962 X4.1366 A4.551
    N2964 X4.131 A4.74
    N2966 X4.125 A4.805
    N2968 X4.119 A4.738
    N2970 X-4.129 Z.6253 A-160.223
    N2972 X-4.1354 A-160.402
    N2974 X-4.1413 A-160.693
    N2976 X-4.1463 A-161.076
    N2978 X-4.1504 A-161.527
    N2980 X-4.1536 A-162.029
    N2982 X-4.1556 A-162.573
    N2984 X-4.1561 A-162.873
    N2986 X-4.1563 A-163.179
    N2988 Z.6251 A-174.281
    N2990 X-4.1558 A-174.85
    N2992 X-4.154 A-175.401
    N2994 X-4.1509 A-175.908
    N2996 X-4.147 A-176.362
    N2998 X-4.1421 Z.625 A-176.745
    N3000 X-4.1366 A-177.051
    N3002 X-4.131 A-177.244
    N3004 X-4.1249 A-177.308
    N3006 X-4.1189 A-177.238
    N3008 X4.129 Z.6128 A-12.278
    N3010 X4.1354 A-12.094
    N3012 X4.1413 A-11.805
    N3014 X4.1463 A-11.424
    N3016 X4.1505 A-10.975
    N3018 X4.1536 A-10.47
    N3020 X4.1556 A-9.927
    N3022 X4.1561 A-9.623
    N3024 X4.1563 A-9.321
    N3026 Z.6126 A1.782
    N3028 X4.1558 A2.352
    N3030 X4.154 A2.901
    N3032 X4.1509 A3.408
    N3034 X4.147 A3.858
    N3036 X4.1422 Z.6125 A4.243
    N3038 X4.1366 A4.551
    N3040 X4.131 A4.74
    N3042 X4.125 A4.805
    N3044 X4.119 A4.738
    N3046 X-4.129 Z.6003 A-160.223
    N3048 X-4.1354 A-160.402
    N3050 X-4.1413 A-160.693
    N3052 X-4.1463 A-161.076
    N3054 X-4.1504 A-161.527
    N3056 X-4.1536 A-162.029
    N3058 X-4.1556 A-162.573
    N3060 X-4.1561 A-162.873
    N3062 X-4.1563 A-163.179
    N3064 Z.6001 A-174.281
    N3066 X-4.1558 A-174.85
    N3068 X-4.154 A-175.401
    N3070 X-4.1509 A-175.908
    N3072 X-4.147 A-176.362
    N3074 X-4.1421 Z.6 A-176.745
    N3076 X-4.1366 A-177.051
    N3078 X-4.131 A-177.244
    N3080 X-4.1249 A-177.308
    N3082 X-4.1189 A-177.238
    N3084 X4.129 Z.5878 A-12.278
    N3086 X4.1354 A-12.094
    N3088 X4.1413 A-11.805
    N3090 X4.1463 A-11.424
    N3092 X4.1505 A-10.975
    N3094 X4.1536 A-10.47
    N3096 X4.1556 A-9.927
    N3098 X4.1561 A-9.623
    N3100 X4.1563 A-9.321
    N3102 Z.5876 A1.782
    N3104 X4.1558 A2.352
    N3106 X4.154 A2.901
    N3108 X4.1509 A3.408
    N3110 X4.147 A3.858
    N3112 X4.1422 Z.5875 A4.243
    N3114 X4.1366 A4.551
    N3116 X4.131 A4.74
    N3118 X4.125 A4.805
    N3120 X4.119 A4.738
    N3122 X-4.129 Z.5753 A-160.223
    N3124 X-4.1354 A-160.402
    N3126 X-4.1413 A-160.693
    N3128 X-4.1463 A-161.076
    N3130 X-4.1504 A-161.527
    N3132 X-4.1536 A-162.029
    N3134 X-4.1556 A-162.573
    N3136 X-4.1561 A-162.873
    N3138 X-4.1563 A-163.179
    N3140 Z.5751 A-174.281
    N3142 X-4.1558 A-174.85
    N3144 X-4.154 A-175.401
    N3146 X-4.1509 A-175.908
    N3148 X-4.147 A-176.362
    N3150 X-4.1421 Z.575 A-176.745
    N3152 X-4.1366 A-177.051
    N3154 X-4.131 A-177.244
    N3156 X-4.1249 A-177.308
    N3158 X-4.1189 A-177.238
    N3160 X4.129 Z.5628 A-12.278
    N3162 X4.1354 A-12.094
    N3164 X4.1413 A-11.805
    N3166 X4.1463 A-11.424
    N3168 X4.1505 A-10.975
    N3170 X4.1536 A-10.47
    N3172 X4.1556 A-9.927
    N3174 X4.1561 A-9.623
    N3176 X4.1563 A-9.321
    N3178 Z.5626 A1.782
    N3180 X4.1558 A2.352
    N3182 X4.154 A2.901
    N3184 X4.1509 A3.408
    N3186 X4.147 A3.858
    N3188 X4.1422 Z.5625 A4.243
    N3190 X4.1366 A4.551
    N3192 X4.131 A4.74
    N3194 X4.125 A4.805
    N3196 X4.119 A4.738
    N3198 X-4.129 Z.5503 A-160.223
    N3200 X-4.1354 A-160.402
    N3202 X-4.1413 A-160.693
    N3204 X-4.1463 A-161.076
    N3206 X-4.1504 A-161.527
    N3208 X-4.1536 A-162.029
    N3210 X-4.1556 A-162.573
    N3212 X-4.1561 A-162.873
    N3214 X-4.1563 A-163.179
    N3216 Z.5501 A-174.281
    N3218 X-4.1558 A-174.85
    N3220 X-4.154 A-175.401
    N3222 X-4.1509 A-175.908
    N3224 X-4.147 A-176.362
    N3226 X-4.1421 Z.55 A-176.745
    N3228 X-4.1366 A-177.051
    N3230 X-4.131 A-177.244
    N3232 X-4.1249 A-177.308
    N3234 X-4.1189 A-177.238
    N3236 X4.129 Z.5378 A-12.278
    N3238 X4.1354 A-12.094
    N3240 X4.1413 A-11.805
    N3242 X4.1463 A-11.424
    N3244 X4.1505 A-10.975
    N3246 X4.1536 A-10.47
    N3248 X4.1556 A-9.927
    N3250 X4.1561 A-9.623
    N3252 X4.1563 A-9.321
    N3254 Z.5376 A1.782
    N3256 X4.1558 A2.352
    N3258 X4.154 A2.901
    N3260 X4.1509 A3.408
    N3262 X4.147 A3.858
    N3264 X4.1422 Z.5375 A4.243
    N3266 X4.1366 A4.551
    N3268 X4.131 A4.74
    N3270 X4.125 A4.805
    N3272 X4.119 A4.738
    N3274 X-4.129 Z.5253 A-160.223
    N3276 X-4.1354 A-160.402
    N3278 X-4.1413 A-160.693
    N3280 X-4.1463 A-161.076
    N3282 X-4.1504 A-161.527
    N3284 X-4.1536 A-162.029
    N3286 X-4.1556 A-162.573
    N3288 X-4.1561 A-162.873
    N3290 X-4.1563 A-163.179
    N3292 Z.5251 A-174.281
    N3294 X-4.1558 A-174.85
    N3296 X-4.154 A-175.401
    N3298 X-4.1509 A-175.908
    N3300 X-4.147 A-176.362
    N3302 X-4.1421 Z.525 A-176.745
    N3304 X-4.1366 A-177.051
    N3306 X-4.131 A-177.244
    N3308 X-4.1249 A-177.308
    N3310 X-4.1189 A-177.238
    N3312 X4.129 Z.5128 A-12.278
    N3314 X4.1354 A-12.094
    N3316 X4.1413 A-11.805
    N3318 X4.1463 A-11.424
    N3320 X4.1505 A-10.975
    N3322 X4.1536 A-10.47
    N3324 X4.1556 A-9.927
    N3326 X4.1561 A-9.623
    N3328 X4.1563 A-9.321
    N3330 Z.5126 A1.782
    N3332 X4.1558 A2.352
    N3334 X4.154 A2.901
    N3336 X4.1509 A3.408
    N3338 X4.147 A3.858
    N3340 X4.1422 Z.5125 A4.243
    N3342 X4.1366 A4.551
    N3344 X4.131 A4.74
    N3346 X4.125 A4.805
    N3348 X4.119 A4.738
    N3350 X-4.129 Z.5003 A-160.223
    N3352 X-4.1354 A-160.402
    N3354 X-4.1413 A-160.693
    N3356 X-4.1463 A-161.076
    N3358 X-4.1504 A-161.527
    N3360 X-4.1536 A-162.029
    N3362 X-4.1556 A-162.573
    N3364 X-4.1561 A-162.873
    N3366 X-4.1563 A-163.179
    N3368 Z.5001 A-174.281
    N3370 X-4.1558 A-174.85
    N3372 X-4.154 A-175.401
    N3374 X-4.1509 A-175.908
    N3376 X-4.147 A-176.362
    N3378 X-4.1421 Z.5 A-176.745
    N3380 X-4.1366 A-177.051
    N3382 X-4.131 A-177.244
    N3384 X-4.1249 A-177.308
    N3386 X-4.1189 A-177.238
    N3388 X4.129 Z.4878 A-12.278
    N3390 X4.1354 A-12.094
    N3392 X4.1413 A-11.805
    N3394 X4.1463 A-11.424
    N3396 X4.1505 A-10.975
    N3398 X4.1536 A-10.47
    N3400 X4.1556 A-9.927
    N3402 X4.1561 A-9.623
    N3404 X4.1563 A-9.321
    N3406 Z.4876 A1.782
    N3408 X4.1558 A2.352
    N3410 X4.154 A2.901
    N3412 X4.1509 A3.408
    N3414 X4.147 A3.858
    N3416 X4.1422 Z.4875 A4.243
    N3418 X4.1366 A4.551
    N3420 X4.131 A4.74
    N3422 X4.125 A4.805
    N3424 X4.119 A4.738
    N3426 X-4.129 Z.4753 A-160.223
    N3428 X-4.1354 A-160.402
    N3430 X-4.1413 A-160.693
    N3432 X-4.1463 A-161.076
    N3434 X-4.1504 A-161.527
    N3436 X-4.1536 A-162.029
    N3438 X-4.1556 A-162.573
    N3440 X-4.1561 A-162.873
    N3442 X-4.1563 A-163.179
    N3444 Z.4751 A-174.281
    N3446 X-4.1558 A-174.85
    N3448 X-4.154 A-175.401
    N3450 X-4.1509 A-175.908
    N3452 X-4.147 A-176.362
    N3454 X-4.1421 Z.475 A-176.745
    N3456 X-4.1366 A-177.051
    N3458 X-4.131 A-177.244
    N3460 X-4.1249 A-177.308
    N3462 X-4.1189 A-177.238
    N3464 X4.129 Z.4628 A-12.278
    N3466 X4.1354 A-12.094
    N3468 X4.1413 A-11.805
    N3470 X4.1463 A-11.424
    N3472 X4.1505 A-10.975
    N3474 X4.1536 A-10.47
    N3476 X4.1556 A-9.927
    N3478 X4.1561 A-9.623
    N3480 X4.1563 A-9.321
    N3482 Z.4626 A1.782
    N3484 X4.1558 A2.352
    N3486 X4.154 A2.901
    N3488 X4.1509 A3.408
    N3490 X4.147 A3.858
    N3492 X4.1422 Z.4625 A4.243
    N3494 X4.1366 A4.551
    N3496 X4.131 A4.74
    N3498 X4.125 A4.805
    N3500 X4.119 A4.738
    N3502 X-4.129 Z.4503 A-160.223
    N3504 X-4.1354 A-160.402
    N3506 X-4.1413 A-160.693
    N3508 X-4.1463 A-161.076
    N3510 X-4.1504 A-161.527
    N3512 X-4.1536 A-162.029
    N3514 X-4.1556 A-162.573
    N3516 X-4.1561 A-162.873
    N3518 X-4.1563 A-163.179
    N3520 Z.4501 A-174.281
    N3522 X-4.1558 A-174.85
    N3524 X-4.154 A-175.401
    N3526 X-4.1509 A-175.908
    N3528 X-4.147 A-176.362
    N3530 X-4.1421 Z.45 A-176.745
    N3532 X-4.1366 A-177.051
    N3534 X-4.131 A-177.244
    N3536 X-4.1249 A-177.308
    N3538 X-4.1189 A-177.238
    N3540 X4.129 Z.4378 A-12.278
    N3542 X4.1354 A-12.094
    N3544 X4.1413 A-11.805
    N3546 X4.1463 A-11.424
    N3548 X4.1505 A-10.975
    N3550 X4.1536 A-10.47
    N3552 X4.1556 A-9.927
    N3554 X4.1561 A-9.623
    N3556 X4.1563 A-9.321
    N3558 Z.4376 A1.782
    N3560 X4.1558 A2.352
    N3562 X4.154 A2.901
    N3564 X4.1509 A3.408
    N3566 X4.147 A3.858
    N3568 X4.1422 Z.4375 A4.243
    N3570 X4.1366 A4.551
    N3572 X4.131 A4.74
    N3574 X4.125 A4.805
    N3576 X4.119 A4.738
    N3578 X-4.129 Z.4253 A-160.223
    N3580 X-4.1354 A-160.402
    N3582 X-4.1413 A-160.693
    N3584 X-4.1463 A-161.076
    N3586 X-4.1504 A-161.527
    N3588 X-4.1536 A-162.029
    N3590 X-4.1556 A-162.573
    N3592 X-4.1561 A-162.873
    N3594 X-4.1563 A-163.179
    N3596 Z.4251 A-174.281
    N3598 X-4.1558 A-174.85
    N3600 X-4.154 A-175.401
    N3602 X-4.1509 A-175.908
    N3604 X-4.147 A-176.362
    N3606 X-4.1421 Z.425 A-176.745
    N3608 X-4.1366 A-177.051
    N3610 X-4.131 A-177.244
    N3612 X-4.1249 A-177.308
    N3614 X-4.1189 A-177.238
    N3616 X4.129 Z.4128 A-12.278
    N3618 X4.1354 A-12.094
    N3620 X4.1413 A-11.805
    N3622 X4.1463 A-11.424
    N3624 X4.1505 A-10.975
    N3626 X4.1536 A-10.47
    N3628 X4.1556 A-9.927
    N3630 X4.1561 A-9.623
    N3632 X4.1563 A-9.321
    N3634 Z.4126 A1.782
    N3636 X4.1558 A2.352
    N3638 X4.154 A2.901
    N3640 X4.1509 A3.408
    N3642 X4.147 A3.858
    N3644 X4.1422 Z.4125 A4.243
    N3646 X4.1366 A4.551
    N3648 X4.131 A4.74
    N3650 X4.125 A4.805
    N3652 X4.119 A4.738
    N3654 X-4.129 A-160.223
    N3656 X-4.1378 A-160.517
    N3658 X-4.1453 A-160.992
    N3660 X-4.1512 A-161.612
    N3662 X-4.1549 A-162.333
    N3664 X-4.156 A-162.753
    N3666 X-4.1563 A-163.179
    N3668 A-174.281
    N3670 X-4.1552 A-175.079
    N3672 X-4.1516 A-175.826
    N3674 X-4.1458 A-176.47
    N3676 X-4.1382 A-176.964
    N3678 X-4.1293 A-177.27
    N3680 X-4.1241 A-177.306
    N3682 X-4.1189 A-177.238
    N3684 X4.129 A-12.278
    N3686 X4.1377 A-11.979
    N3688 X4.1453 A-11.506
    N3690 X4.1511 A-10.887
    N3692 X4.1549 A-10.167
    N3694 X4.156 A-9.747
    N3696 X4.1563 A-9.321
    N3698 A1.782
    N3700 X4.1552 A2.581
    N3702 X4.1516 A3.327
    N3704 X4.1458 A3.968
    N3706 X4.1382 A4.461
    N3708 X4.1293 A4.77
    N3710 X4.1241 A4.802
    N3712 X4.119 A4.738
    N3714 G0 Z1.6875
    N3716 M5
    N3718 G91 G28 Z0.
    N3722 M30
    Aug 2014
    4
    Hi Shane,
    So here's my problem. Your code looks like mine when I post, the biggest difference is the G56.1 and P51 (I'm unfamiliar with those 2 codes), I don't see any lock/unlock codes on your program, so I am assuming that as the machine is reading it that it is "looking ahead" and moving smoothly as a consistent path. What's happening to me is that each time it reads a line the lock/unlock kicks in so it's a short cut/pause/short cut/pause and nothing smooth at this point. Here's a section of the code:
    O1234( MA00353_TEST )
    ( DATE=DD-MM-YY - 15-09-14 TIME=HH:MM - 09:34 )
    ( MATERIAL - ALUMINUM INCH - 2024 )
    ( T4 | 1/4 FLAT ENDMILL | H4 )
    N100 G20
    N110 G0 G17 G40 G49 G80 G90
    N120 T4 M6
    N130 G0 G90 G54 X-.2199 Y.4904 A-33.72 S8404 M3
    N140 G43 H4 Z3.3862
    N150 Z1.3862
    N160 G1 Z1.1362 F25.
    N170 X-.2108 Y.4446 Z1.0809
    N180 X-.2006 Y.3928 Z1.0313
    N190 X-.1892 Y.3357 Z.9882
    N200 X-.177 Y.2742 Z.9521
    N210 X-.1641 Y.2089 Z.9236
    N220 X-.1506 Y.1408 Z.9029
    N230 X-.1367 Y.0709 Z.8904
    N240 X-.1226 Y0. Z.8862
    N250 X-.1144 Z.8852 A-36.412 F100.
    N260 X-.1061 Z.8861 A-39.104
    N270 X-.0977 Z.8851 A-41.835
    N280 X-.0894 Z.8861 A-44.567
    N290 X-.0814 Z.8852 A-47.168
    N300 X-.0735 Z.8862 A-49.769
    N310 X-.0656 Z.8852 A-52.32
    This is as output from my MCX5 file and it won't allow the machine to cut smooth and continuous. Am I missing something here?
    Thanks for the help!
    John
    Jul 2010
    492
    i took those out when i ran it, changed it to g54.
    we hired out for this program, but it was pretty smooth running, no real pauses like you describe, which i have seen before as well....
    Jun 2008
    71
    Did you figure it out yet? Is it something you can program conveniently? I do most of our 4axis stuff right on the control.
    Jun 2010
    104
    I'm not familiar with the VM10i but I have used Milltronics/Centroid machines and the controller itself has configuration to turn this on/off. It's nothing wrong with the gcode.
    Hope that helps
  1. HURCO VM10i
    By 85burban in forum HURCO
    Last Post: 05-10-2014, 01:19 PM
  2. New VM10i Owner: Cheap touch probe options?
    By makerstoolworks in forum HURCO
    Last Post: 11-02-2013, 12:01 AM
  3. 4th axis Hurco
    By Paul Goddard in forum Mastercam
    Last Post: 11-23-2010, 02:48 AM
  4. HURCO 5 AXIS
    By RICK B. in forum HURCO
    Last Post: 11-14-2010, 09:27 AM
  5. New Hurco 5-Axis VMC
    By AppliedMachine in forum News Announcements
    Last Post: 03-26-2010, 11:46 PM
