587,772 active members*
3,071 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > 4th axis compatibility with my Fanuc
    Feb 2017
    3
    Hi there!
    First post here but I can't recall the hour I spent reading thread here! I have a Yang SMV 1000 machining center that is pre-wired for a 4th axis. There is a Fanuc drive for the 4th axis, named A06B-6079-H103.
    I can get my hand on a Fadal 4th axis for a reasonable price but I just want to be sure it's compatible with this drive. Just wanted to check here with more knowledgeble people before I empty the wallet!
    Thanks for reading
    Aug 2007
    793
    Re: 4th axis compatibility with my Fanuc
    if your axis is equipped by compatible Fanuc motor you can attach it
    compatibility of motors and drives you can get from manual for this drive
    Feb 2015
    161
    What kind of control is on the machine? Although the drive may be there, an option may need to be added in order for it to work properly. PLUS, the servo parameters will need to be set up.
  1. Solidcam Fanuc 3-4-5 axis Mill and Fanuc 2-3 axis Turn Posts (2013)
    By calver in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-04-2021, 07:34 PM
  2. FANUC BOARD COMPATIBILITY
    By linx67 in forum Fanuc
    Last Post: 05-21-2020, 03:32 AM
  3. Fanuc Servo compatibility
    By cwtoyota in forum Fanuc
    Last Post: 12-19-2012, 09:04 PM
  4. 64 bit compatibility?
    By Teyber12 in forum Uncategorised CAD Discussion
    Last Post: 06-29-2010, 12:07 AM
  5. Compatibility
    By elogicca in forum Open Source Controller Boards
    Last Post: 06-09-2006, 10:34 PM
