587,256 active members*
2,877 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 4 Axis - Axis Substitution
Results 1 to 5 of 5
    Oct 2009
    77
    I have milled a couple of slots around a cylinder using axis substitution and it works fine. However the problem I am having trying to understand is why does the cylinder have to be centered on the X axis? That is the only way I got it to work..
    As well does someone have any more 4th axis, axis substitution files that I can practice on ?
    Dec 2008
    3122
    Quote Originally Posted by jcnewbie View Post
    Iwhy does the cylinder have to be centered on the X axis?
    It doesn't,
    your "model axis" can be any distance from the "rotary axis", but 99.99% of the time you would put the round work in a 3-jaw and on the same centre-line
    Mastercam uses the "rotary axis line" as the pivot for the angle calculations
    May 2006
    99
    I have had some problems with that as wel. All looks good in mastercam but the post just messes it up so machine does not do what it needs to do.
    Sinds then I always use center of 4th axis as WCS.
    Oct 2009
    77
    Thanks for the info..
    When someone says that I have 3 +1 Machine, does that mean that the machine can rotate in x,y,z and has one extra axis , and that makes it a 4 axis machine ( positional ). And the same for 3+2 Machine, ?
    If a machine can move in all 3 axis on top of the x,y,z, that makes it a 5 axis machine correct?
    May 2006
    99
    I guess the 3+1 is a standard mill with and 4th axis. Usually set on the x-axis.
    A 3+2 might be a tilting 4th axis which makes it possible to set the 4th to an angle and the rotate the "chuck" on the 4th axis.
    Pretty much this is the first time I here of it.
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  3. One axis (z-axis?) computer controlled testing device
    By TsThorsell in forum Stepper Motors / Drives
    Last Post: 02-07-2008, 07:38 PM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. "A" Axis Substitution Macro Programming For Fanuc
    By xleng in forum G-Code Programing
    Last Post: 12-08-2006, 08:52 PM
