587,481 active members*
3,083 visitors online*
IndustryArena Forum > CAM Software > CamWorks > 3D stepover machining
Results 1 to 6 of 6
    Sep 2010
    16
    HI ,sometimes when i mill some electrodes 3D stepover seems like the bes way to finish the piece but i cant get it to start miling from top down (imagine the part is basically conical ) but instead it goes from bottom up wich makes it dive into more material in the start.This makes me take more steps with smaller and smaller bits to come to a point where the last mill bit (2mm diameter) can work safely in good feed speed.
    Delcam power mil had the option to select wheather you want to go inside out or outside in but i just cant seem to get it in camworks2009.
    I would appreciate if anyone can share a pearl of wisdom on the subject.
    Thanx
    Jun 2006
    38
    have you tried using z-level instead of pattern project?
    even in pattern project, you can reverse the stepover, that might work for you also.
    Sep 2010
    16
    Quote Originally Posted by yoshi900 View Post
    thanx for the reply ,i kind of messed with it and made it work for me.not quite as i'd like to but it works.
    when i reverse i does start from the other side but has some moves i did not like.
    Z level works sometimes but its not a full 3D that i need for some parts.
    Mar 2008
    638
    I use "Fine-constant step over" a lot for parts that I need a good finish. You can set both XY and Z step overs.
    Sep 2010
    16
    Quote Originally Posted by extanker59 View Post
    i run a CamWorks 2009 and i cant find constant stepover , only 2D and 3D stepover wich is something like that.
    But as i explained the constant stepover used to give much better results in Delcam powermill.
    May 2006
    107
    hi
    under the pass options is a Reverse Order, tick or untick this and it will change the start order around for you.
  1. Maximum Stepover / Stepdown and Total Tolerance
    By jcnewbie in forum Mastercam
    Last Post: 11-20-2009, 03:12 AM
  2. TAIG: Aluminum - Full-cut vs. stepover
    By tikka308 in forum Taig Mills / Lathes
    Last Post: 03-06-2008, 10:34 PM
  3. Stepover and ball/end mill
    By Sanghera in forum DIY CNC Router Table Machines
    Last Post: 08-02-2006, 03:54 AM
  4. Tool Stepover help
    By moto21 in forum Mastercam
    Last Post: 08-23-2005, 02:03 AM
  5. Stepover
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-10-2005, 06:07 AM
