587,420 active members*
3,315 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 3D Milling Z axis to high on + side of concave surface
Results 1 to 4 of 4
    Sep 2007
    84
    Hello,
    I was running a test convex & concave surface. Basically a bowl with a bump in the middle. It appears at the transition from running - to +. It ran flawlessly until this point 14000 line in or so.Z went to -0.2760. Clearly off material.I though at first it was too fast on feed where it went too high before stopping or maybe a backlash issue. I'm open for thoughts and suggestions. I'm glad i ran a test.
    Craig,
    Solid Cam 2010
    Mach3
    Code attached.
    Apr 2004
    5747
    Without knowing more about your machine or how you're running it it's hard to say what the problem is, but I doubt it's backlash. It sounds more like a lost steps issue.
    Andrew Werby
    Website
    Sep 2007
    84
    Awerby,
    I ran another test this evening. I did hear the Z stall or have some sort of issue. Subsequently same problem. I believe i was running to fast. I'll do some tweaking and see what happens.
    Thank you
    Feb 2011
    252
    Re: 3D Milling Z axis to high on + side of concave surface
    Use the HSS, it is easier to determine the tool path.
  1. linear 3d milling doesn't want to mill high inclinaison surface ?
    By greg2fs in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-31-2013, 11:33 AM
  2. Achieving a smooth finish on a concave surface
    By Ariel6789 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-21-2011, 05:39 PM
  3. Replies: 0
    Last Post: 04-07-2011, 02:43 PM
  4. Concave Milling
    By Travisty in forum Mastercam
    Last Post: 10-20-2009, 01:56 PM
  5. Replies: 11
    Last Post: 10-13-2007, 07:03 AM
