587,726 active members*
3,429 visitors online*
Results 1 to 2 of 2
    Apr 2014
    3
    3D Milling Machine Problem
    Hi, this is my first post.
    I'm setting up a Rong Fu 45 for 3d CNC. I'm using Mach 3, PMDX 126, and Gecko 320. I have the y axis jogging. I did have the x axis jogging. However, the x axis ran into some problems. It will now jog to the right, but faults out to the left after moving only a fraction of an inch. I find it very hard if not impossible to make an x-move manually with the shaft knob (power disconnected). This mill has been sitting around not being used for a few years. I think it probably needs to be lubed, or possibly something is bound. If I take the belt off the motor, it runs fine; no feedback of course.
    I have no manual for this mill, and have no idea how to remove the table in order to inspect an lube.
    thanks, rex
    Apr 2004
    5750
    Re: 3D Milling Machine Problem
    It does sound like a mechanical problem. You'll probably have to disassemble it at least partially to see what's hanging up. When you do this, de-rust, clean, and lubricate everything you come across. If you really can't figure out how to get it apart, try posting something a lot more specific, like "Disassembly Instructions for RF 45?"
    Andrew Werby
    Website
  1. Help with a problem on the DMF 180 cnc milling machine
    By Droste in forum Community Club House
    Last Post: 07-08-2013, 10:28 AM
  2. CNC Milling Machine: PWM Control Problem
    By phyllis_ave in forum Controller & Computer Solutions
    Last Post: 10-02-2009, 07:36 AM
  3. About Engraving and Milling Machine Application Problem
    By kkk123 in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2008, 02:22 AM
  4. Fanuc 15ma - Kafo milling machine problem!
    By F.Sharifi in forum Fanuc
    Last Post: 06-09-2007, 07:58 PM
