I am trying to cut a 4 degree negative taper with a 6 degree dovetail type tool with a .010" corner radius on it. I got it to cut right with a Surface Flowline tool path but can't get it to retract without gouging the part. How do I get it to go to the center of the taper before retracting? Or should I try a different type of tool path?
I am using a Makino 3-axis machine.
