587,192 active members*
2,336 visitors online*
Results 1 to 4 of 4
    Mar 2006
    255
    Angry 3axis to 5axis
    Hey
    Long time, I just have a quick query, can you change a model in the CAM-Part definition from Axis - 3axis to 5axis, currently this is greyed out. I know it probably needs some easy fix, but I am now moving the part onto a 5 axis machine, but everytime I Gcode out, it is not right.
    I need that greyed out area to be active. I spent a few hours do a whole program, then realised it was set to 3 axis, now can't get the thing to change.
    please help
    pinguS
    Jan 2010
    81
    Hey there,
    My version toggles between 3 and 5 axis ok so I'm just wondering if you need to select a different licence first on your set up ?
    Oct 2007
    499
    It depends on (a) how your license is set-up and (b) how your post processor is built. To switch between 3D and 5X your machine needs to have a full five axis post or you need to change the CNC controller in the CAM settings to a machine which is 5X capable. Some people have 2 different posts for their machine - a vanilla 3D and a 5X one (though I must confess I don't quite understand why).
    Mar 2006
    255
    Ok, I do have a partial 5 axis post, basically position and mill, no surface milling. However when I reprogrammed the part by selecting the 5axis post first, the greyed out area says 5axis.
    But then I thought I try the post on the program that said 3axis, and the output was exactly the same, so now I'm wondering what is this selection box actually for??
  1. Help with first diy 3axis
    By rayder13 in forum DIY CNC Router Table Machines
    Last Post: 07-22-2009, 02:03 PM
  2. help me design 5axis cnc (please?)
    By Nick_Black in forum Open Source CNC Machine Designs
    Last Post: 07-09-2008, 12:45 AM
  3. what is the best 5axis software
    By 5axisatm in forum Uncategorised CAM Discussion
    Last Post: 02-08-2008, 11:52 PM
  4. 5axis Help
    By jybute in forum Haas Mills
    Last Post: 11-22-2006, 03:10 PM
  5. 3axis DRO
    By Klox in forum DNC Problems and Solutions
    Last Post: 06-04-2003, 07:32 AM
