587,443 active members*
3,454 visitors online*
Results 1 to 5 of 5
    Nov 2010
    64
    360 Brass rings, 1.5" diameter
    I need brass ring made from 360.
    1.5" O.D.
    1" I.D.
    .100 thick
    4 counter sunk holes every 90* that use a M3 flat head screw, so about .120 hole and looks like about .090 on the countersink? Holes are 1.25" on center.
    Qty about 300 unless there is a better price on up.
    Please give a quote and also an estimated time on delivery. You can reply here or to my email [email protected]
    Picture below is .300 thick but same otherwise
    Jun 2008
    262
    needs to be alloy 360?
    Thanks in advance!
    i build the braces that keep american teeth straight......tick tick tick
    Nov 2010
    64
    Not necessarily.
    The purpose is for weight and I do need them to match some existing stock. If you have something that you think would fit the bill, let me know.
    Quote sent via email.
    Thank you for your time.
    Nov 2010
    64
    Thanks to everybody for the quotes! I think I have plenty to look over at this point.
    I will look over all the quotes and let you guys know.
  1. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  2. Conical Boring 6.968" diameter, down to .250" diameter, over a 7.776" length
    By HaroldSAJS in forum Mechanical Calculations/Engineering Design
    Last Post: 06-08-2012, 09:29 PM
  3. 3/8" Outer Diameter Hollow Brass Cylinder
    By akira7799 in forum RFQ (Request for Quote)
    Last Post: 03-29-2011, 01:32 AM
  4. Small batch of Acrylic 80mm-diameter "rings" needed
    By theorie in forum Employment Opportunity
    Last Post: 03-02-2011, 09:47 PM
  5. turning .003 diameter brass wire
    By camtd in forum CNC Swiss Screw Machines
    Last Post: 06-14-2008, 06:15 PM
