587,421 active members*
3,185 visitors online*
Results 1 to 4 of 4
    Jan 2012
    0
    300- alarm. write protect
    I recently replaced APC batteres on fanuc series io - mate mill. and tried resseting the reference point parameter but i always get a "write protect" mesage.
    need help on how to perform zero return (300 alarm)
    thanks!
    Oct 2009
    297
    What kind of machine do you have?
    What value do you have in parameter 1815?
    Regards
    Alex
    Jan 2012
    0
    parameter 1815 has Apc set to 1 and APZ set to 0 when i try to change the zero to 1 it says "write protect"
    The machine is an Ajax spark X with fanuc series io - mate.
    Thanks!
    Oct 2009
    297
    Push the hard key offsets/settings, go in the setting menu by pushing the soft key settings. In MDI mode change PWE=0 to a 1.An alarm 100 will appear! (meaning pwe=1)
    Try to change parm 1815 bit 4 to a one. Alm 000 will apear to power off the control. Change PWE=1 to a zero.
    Power off and on the control. Make sure the zero position of the axis is the correct one.
    Alex.
  1. Alarm 232-4 sensor protect
    By Jelle_b_k in forum Okuma
    Last Post: 01-30-2024, 10:02 AM
  2. Fanuc 11m parameter write protect
    By BrianM03 in forum Fanuc
    Last Post: 06-14-2010, 04:17 PM
  3. Replies: 8
    Last Post: 04-30-2010, 11:54 AM
  4. FANUC 15T Write Protect
    By bmlw in forum Fanuc
    Last Post: 10-11-2008, 08:47 PM
  5. Protect your G54...G59
    By jorgehrr in forum Fanuc
    Last Post: 10-01-2007, 01:11 AM
