587,431 active members*
3,113 visitors online*
Thread: 3 Steppers?
Results 1 to 5 of 5
    Jun 2003
    65
    3 Steppers?
    I have 3 steppers
    (2) 1200Oz. in - 6.0Amps DC per phase (2 phase)
    (1) 270Oz. in - 2.8Amps DC per phase (1 phase)
    I'm having 70.7VDC running through, do i need any type of resistor on the small motor?
    thxs
    35538
    What drives are you using, and what are the motors' rated voltages?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jun 2003
    65
    270Oz in. ( 3.75 rated Voltage)
    1200Oz in. ( 2.7 rated Voltage )
    I'm using Gecko Drives G201.
    I got all the motors from Homeshopcnc: http://www.homeshopcnc.com/page3.html
    Aug 2004
    2849
    No, but use the proper current limit resistor on each Gecko.
    35538
    The 1200 oz motor might get pretty hot due to the higher voltage. It really should have about 60V max.
    Gerry
  1. power of using unipolar steppers?
    By dowling177 in forum Stepper Motors / Drives
    Last Post: 01-12-2005, 03:10 AM
  2. Just found some steppers!
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 08-15-2004, 01:32 AM
  3. Choosing Steppers
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 06-18-2004, 05:21 AM
  4. steppers and current
    By ullbergm in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:24 PM
