I AM HAVING PROBLEMS WITH 3-D, 2-D WORKS FINE TOOL PATH WHEN I TRY I GET A ACCESS DENIED POP UP I WENT TO THE WEB SITE AND IT SAID TO TRY AND UPDATE THE LICENSES WHICH I DID STILL NO LUCK I THEN UPDATED THE PROGRAM, V-22 BY THE WAY. STILL NO LUCK I CALLED TECH SUPPORT THEY SENT ME A E-MAIL WITH AN UPDATE FOR THE LICENSES BUT EVERY TIME I TRIED TO UPGRADE IT KILLED THE PROGRAM, I THEN DID A SYSTEM RESTORE BACK TO BEFORE I UPDATED V-22 AND WENT BACK TO THE WEB SITE AND DOWNLOADED THE UPDATE FOR V-22 AND SAVED IT TO DESKTOP AND LOADED IT FROM THIER SAME RESULT I HAVE TRIED TO CONTACT TECH SUPPORT BUT THEY ARE APPARENTLY SWAMPED WITH CALLS HAS ANYONE HAD THE SAME PROBLEM THANKS
