587,486 active members*
4,028 visitors online*
IndustryArena Forum > CNC Electronics > PIC Programing / Design > 3 axis stepper motor driver using a single PIC
Results 1 to 6 of 6
    Apr 2007
    17
    What kind of signals does Mach3 output to the stepper driver? What inputs should I have if I want to design a stepper driver with a PIC?
    David.
    Jun 2003
    3312
    the most common method is step/direction controllers. mach3, cncpro,turbocnc, kcam etc.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Feb 2007
    532
    Quote Originally Posted by david90 View Post
    David.
    I did this with a PIC16F870 for my first CNC last year: (Simple half-step unipolar design)
    http://www.trash.co.nz/3step
    (That website may vanish, it was a work in progress last year, and I'm about to shift it to another site and finish it)
    The thread on the machine, which mentions the controller a bit is here:
    http://www.cnczone.com/forums/showthread.php?t=33153
    You'll find that you have problems with simultaneous pulses if you go down this path, I used caps on the inputs to stretch the input pulses then clear the cap ("Latch") with another pin after servicing the input.
    Cheers, Chris H.
    Feb 2007
    532
    Just replying to myself for the benefit of anyone who reads this thread in the future, I've shifted the 3step design info to http://ohmark.co.nz/3step.html
    I'll finish writing up the 'building' page with some more info on the powersupply / power resistors tonight.
    Jun 2005
    87
    Help rs232
    Ok I looked at your site and noticed you were using RS232 with a max 232 I think none the less, I need a link to the standards used like with KCam, ect, not the rs232 protocol but the data that we will insert in , example xstep how do we send that ystep ydir xdir how do we send this is there a standard, or do we just send it in with the serial send command, once I have communication with the PIC I need help after that point, please do not refer me to serial protocols that is not what I am looking for, just the nuts and bolts of the control board, I need to know how it sees the xstep, and I will be running from there. please help me, as I have asked many and they all keep sending me back to the serial protocol that is not what I want.
    Feb 2007
    532
    Quote Originally Posted by frog View Post
    Hi-ho,
    Sorry, I think you've been looking at the stuff on the site about the process controller project I'm working on which is serial based.
    The 3Step stepper controller uses a standard parallel port interface. Take a look at the PDF circuit diagram at http://ohmark.co.nz/3stepfiles.html.
    I might change the layout of the site menu a bit so it's more obvious which pages go with which project, as I'm intending to put quite a bit of stuff on there this year...
    Cheers, Chris H.
  1. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
  2. Stepper Motor Driver
    By droddis in forum DIY CNC Router Table Machines
    Last Post: 07-31-2007, 01:03 AM
  3. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  4. Dual and single shaft stepper motor differences?
    By Menatep in forum Stepper Motors / Drives
    Last Post: 04-09-2007, 04:22 PM
  5. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
