587,259 active members*
3,056 visitors online*
    Nov 2012
    46
    2006 Made from plywood, not MDF question.
    Has anyone published plans to make the 2006 out of plywood instead of MDF?
    I have a friend with a water jet table, MDF doesn't play well with water, so I was thinking about using regular premium grade or birch or other high end ply-woods instead.
    Any thoughts?
    Feb 2007
    4553
    Post
    Quote Originally Posted by johnyac View Post
    Any thoughts?
    Its possible to make subtle adjustments (scaling) the dxf files to accommodate the thickness difference in the material you would like to use.
    Either scale the dimensions in your cad program or adjust the scale in Mach3.
    A waterjet will cut plywood however eliminating swelling due to open edges may be an issue.
    Cutting Plywood With A WaterJet - YouTube
    Common sense dictates allowing the wood to dry thoroughly before glue-up.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2004
    3215
    A high grade plywood laminate will work, People have built machines out of Ply, but in the right environment (humidity controlled) MDF is more stable. However Due to the torsion Box contraction the Higher grade Plywood should work well.
    One note on the sides of the gantry you may want to provide some angle iron to help stabilize that section.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  1. Z Carriage Width Question on a New Joe's 2006 Build
    By srichey in forum Joes CNC Model 2006
    Last Post: 10-23-2013, 06:21 PM
  2. Joes 2006 Newbie Question
    By nuke33 in forum Joes CNC Model 2006
    Last Post: 04-28-2012, 01:27 AM
  3. Hand Cutting a Joes 2006 - 1 question...
    By racedirector in forum Australia, New Zealand Club House
    Last Post: 11-21-2011, 11:36 AM
  4. One final question about Joes 2006.
    By ShinedBrass in forum Australia, New Zealand Club House
    Last Post: 05-08-2011, 11:52 AM
  5. Has anyone made the jgro from plywood?
    By Markwind in forum Commercial CNC Wood Routers
    Last Post: 10-15-2010, 12:23 PM
