Hello All,
This is my second topic on this forum, the first issue (x-axis encoder problem on the same machine) was resolved with the help of you for which I thank you all again.
Unfortunately (for me) I am in need of some assistance again. Here it goes:
We recently moved our shop (hired a pro rigger to move the machine etc.) and I am now trying to recommission my my Arrow 500 (year 2000, A2100 control, blue vickers drives.) after having wired everything just the way it was at the old shop, I tried to power it up without success.
Voltages at the machine disconnect are ~230 line to line between all three phases, when the disconnect is powered up, machine fans go etc. as expected, however, when I go to power up the control by pressing the green button on the pendant, the screen flashes once and remains dark. The first time I did this, I noticed all the LEDs on the manual pulse generator light up for about a second and then go out. During every subsequent attempt at powering up the machine, these LEDs remained unlit.
I would assume that it is not necessarily a power supply issue since the screen does flash, however, I am just guessing here.
Any thoughts, advice, or similar experiences (hopefully with solutions :-) ) would be greatly appreciated.
Many thanks in advance,
Kind Regards,
ih
