I'm going to be roughing out A2 on a 20 hp Haas Vertical Mill using a 2inch course roughing endmill. Could someone help me out with some cutting calculations.
Can you get info from cutter manufacturer? What is the brand name? Brubaker or ??????
Dick Z
DZASTR
Need more data to make a firm recommendation. Or, you can get a 30 day trial of G-Wizard and calculate a bunch of scenarios:
The new materials database includes A2 with several conditions.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Man, get rid of that rough endmill. Get a carbide 1" four flute and go to town at 200 SFM. A2 machines good.
Dan
i like fine tooth over the large tooth, seems to have less tool pressure.
