587,913 active members*
3,755 visitors online*
Results 1 to 4 of 4
    Jan 2007
    3
    Question 1996BRIDGEPORT V2XT DX32 DOS 6.2
    In Dire need of help with reviving my old mill.. In awesome shape... been sitting for 3 years. did a scandisk after finally getting it to boot to some level and it has at least 5 bad sectors... it gets to the dx 32 screen then it says : cant load *.fnt file then it says loading operation interface
    then it goes to abort ignore fail and will not do anything else
    It is showing the file bxx.exe and bdx.exe exist but they are empty.. 0kb
    unless i hear otherwise ithink im gonna try to rebuild the computer part then see if i can find software..(dos 6.2 and win 3.11 for workgroup and boss dx32 anything else!!?)
    I will need some legacy parts.. like a new (old)? hard drive etc) and I am looking for a copy of the boss dx32 software (or is it hardwired in??) thanks in advance for ANY guidance!!
    Nov 2009
    58
    5 bad sectors - likely from a hard drive crash.
    It will prob b ok after a reformat - i would move the info to a current computer.
    Attempt to recover the damaged files- not likely
    If you can find the dx32 software you should be in good shape.
    DOS 6 or 6.2_ is available if you look hard or have a friend
    here is a DOS compatible hard drive (2GB max)
    Toshiba unit - $60
    Toshiba 2.16GB Hard Drive (ATA/ 16) - MK-2104MAV
    Good luck sounds like fun!!!
    Sep 2004
    10
    Any CF card is ATA harddisk. I'm use CF card 1GB and "CF2IDE" adaptor in my system. only 5US for CF2IDE. Very fast transfer. No turnning device.
    Jan 2007
    3
    thanks
    thanks guys i will try all i suggestions this weekend as i am forced down to a weekend warrior! It would be awesome to funnel down to compact flash... I want to modernize it to the best the budget and bridgeport capability will bring...!
  1. dx32 dnc
    By Alan bailey in forum Bridgeport / Hardinge Mills
    Last Post: 10-06-2020, 02:51 PM
  2. Bridgeport V2XT / DX32 running Windows XP?
    By 5S Dude in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2010, 05:40 PM
  3. Desperately in need of DX32 V2XT manuals.
    By Tallrs in forum Bridgeport / Hardinge Mills
    Last Post: 04-15-2009, 01:27 AM
  4. New to me 308 with DX32
    By Ranchero50 in forum Bridgeport / Hardinge Mills
    Last Post: 04-11-2008, 05:12 PM
  5. V2XT- DX32 : Programing Z axis Question
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 12-28-2006, 04:46 PM
