587,787 active members*
5,284 visitors online*
    Feb 2006
    123
    160MC lost file
    So I have a mill that has been lying around for years, its a 1997 160MC DOS based Open System It I replaced the dead batteries in the PC and the HSSB and it tries the boot up but just up in DOS Com error between the HSSB and PC, Fiber optic cable seems ok but it says missing file please install MMCSYS.EXE. Fanuc don't seem to be any help, any ideas would be a shame to scrap the machine it's an Okada Graphite mill 25000rpm.
    Thanks.
    Nov 2011
    13
    Re: 160MC lost file
    Hi dresda
    your Hard disk is not booting up or is faulty
    this is a windows NT system
    you need to see if your Hard disk is working
    the file the system is looking for should be in the root dir of the HDD
    best of luck
    theBlackWatch
    Feb 2006
    123
    Re: 160MC lost file
    Hey the BlackWatch, My machine is in DOS, i think some others come in windows 95/NT so when I first start it up it hangs up passing the hard drive test and sits there with the curser flashing then If I pull the fibre optic cable from the back of the CRT and that goes directly to the HSSB board I get a com error and it says press any key and when I do that the PC side boots up so I can see the position screen offsets etc, looks a bit like Fanuc but it's not, If I go to diagnostics the alarm will be displayed saying missing file please install MMCSYS.exe. Fanuc now get back to me and say I need MDI drive & Library disk but they would have to get it from Japan because they don't have the licence to make a copy for $1500. US and there guy would have to install it, give me a break.
  1. MadCAM options file lost
    By grahamkirkland in forum MadCAM
    Last Post: 03-02-2016, 11:18 AM
  2. Dongle lost: please convert a file for me
    By matthiaswm in forum LaserCut
    Last Post: 05-06-2013, 05:47 AM
  3. SQT100MSY M6Y_ymw-TPLC file lost!
    By jacky21cn in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-02-2012, 03:32 PM
  4. Lost or corrupt file
    By ErnieD in forum Tormach Personal CNC Mill
    Last Post: 01-29-2012, 06:32 PM
  5. fanuc 160mc
    By jetski in forum Fanuc
    Last Post: 11-01-2006, 08:14 PM
