NO. parameters
1 Working area 1300mm*2500mm
2 X axis 1300mm
3 Y axis 2500mm
4 Z axis 40mm
5 X.Yposioning accuracy ≤±0.05mm
6 X Y resettin gposion accuracy ≤±0.01mm
7 X Y max posionting speed 20 m/min
8 Laser power 150W
9 Cooling system CW5200
10 Cutting object precision ±0.05mm/1000mm(steel)
11 Cutting material thickness steel<1.5MM
stainless steel<1.5MM
acrylic<30MM
12 Whole machine size 3600*1850*1300
13 Controller Leetro
14 Weight 1000Kg
15 Power 4KW
16 Voltage 220V
17 Herz 50Hz
The advantages of LC1325M:
LC1325M is a mixing cutting machine, specialized in cutting stainless steel, carbon steel, MDF and arcylic.
High efficiency: The cutting speed of 1mm stainless steel is 1800mm/min.
20mm arcylic with perfect cutting quality.
LC1325M machine is matched with the Panasonic Servo System and high precision.
ball-screw system to ensure the high precision, running stable and long-operation.
Low running cost about 5KVA/hour.
Looking for wholesales sincerely.
Skype: Angela Jinan
Contact: Ms. Angela
MSN: [email protected]
Samples:
http://www.alibaba.com/product-detai...010677842.html
