You shouldn't have a problem which ever way you connect L1/L2, but the fused side should be on the hot lead, so if you want to confirm the correct connection, check by meter whether L1 or L2 is connected to the 3A fuse, this will be the live terminal.
In N.America, if operating on 240, both inputs will be above ground, if 120, one will be hot, one grounded neutral.
If used in Europe, to operate on 240, one lead will be neutral and referenced to ground.
Al.
Albert E.
