587,719 active members*
3,413 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > (1131 Back slide Alarm) on our citizen f20 cnc lathe
Results 1 to 2 of 2
    Oct 2015
    24
    Hello,
    We are showing (1131 Back slide Alarm) on our citizen f20 cnc lathe, if anyone can provide help to fix this. We will be thankful to you for this.
    Regards,
    ZUBAIR
    [email protected]
    Sep 2011
    261
    Re: (1131 Back slide Alarm) on our citizen f20 cnc lathe
    Hello Zubair,
    Although I am not specifically familiar with this alarm, I found some information that may help you. Check out the possible causes listed on this website:
    http://dealerparts.mctz.com/ecommerce/F52025.htm
    1131 BACK SLIDE ALM
    * Only when U50C is equipped
    Same as - X-axis overtravel.
    The fall of back spindle was detected.
    The back slide and the tool post interfered with each other.
    This is the back spindle fall detection alarm.
    Alarm occurs if the back slide lock proximity switch is OFF (DGN. No.18.3 *PRSBSC = 1) while the back spindle in sliding down.
    Recovery procedure;
    1. Select MDI mode.
    2. Set DGN. No.420 bit 3 = 0.
    3. If the back spindle falls;
    Press the Feed Hold and Spindle Stop buttons at same time to forcedly raise the back spindle.
    4. Turn the NC power OFF/ON.
    Occurrence factor;
    • The back spindle fails because of the back spindle is collided with the #2 turret.
    • The back slide lock proximity switch (*PRSBSC) failure or position adjustment failure.
    • Magnetic valve for the back spindle slide UP/DOWN or lock is fail.
    So trying to deciper the Jinglish (japanese-english) it sounds like you entered an interference zone, try disabling interefence check
    or
    You are over travelling, and need to modify tool geometry or your G code
    CNC Product Manager / Training Consultant
  1. citizen a32 S3 alarm
    By nomcnc in forum CNC Swiss Screw Machines
    Last Post: 07-19-2015, 04:58 PM
  2. Citizen c 16 pulls stock back awau from cutoff rool
    By thurminator in forum CNC Swiss Screw Machines
    Last Post: 01-28-2015, 04:15 PM
  3. CITIZEN B12 ALARM
    By mackjordan in forum CNC Swiss Screw Machines
    Last Post: 11-12-2014, 04:49 PM
  4. Citizen L25 Alarm
    By jasonh82 in forum CNC Swiss Screw Machines
    Last Post: 07-12-2012, 08:28 PM
  5. Finding gangtool for citizen L16 back tool
    By mkmk123 in forum CNC Swiss Screw Machines
    Last Post: 07-07-2008, 02:39 PM
