Problem:
X-axis jogging or manual pulse generator causes a SV0013 (vrdy off) fault for ALL axes after normal startup. Y and Z axes move fine.
I have also had SV009 and SV008 alarms on the X axis when trying to re-create the problem. I can't seem to re-create this one though.
Awhile ago, I also had an "improper pulse of pulsecoder" alarm of which I don't recall the number. It was easily reset and hasn't occurred again.
After turning on the machine, I am able to jog and rapid the Y and Z axes w/o any issues. any movement of the X axis triggers the SV0013 alarm on all axes. I am able to move the X axis by approximately .005" to .010" and hear a high pitched noise coming from the motor get louder as I turn the pulse generator
I can turn the x-axis ball-screw by hand across it's full travel. It feels like the same required torque of the Y-axis.
I just re-greased the ball-screw and know that I have a fair amount of way lube getting to the sliding surfaces.
Machine:
Kiwa Excel Center 1200 from ~1988
Fanuc 10M
Red Cap / AC Servo motors
Servo Amp A16B-1100-0220
Axis Control A16B-1211-0271
X-Axis motor is a 5S
At this point I'm having trouble even diagnosing the problem. Any help would be appreciated.
This issue just HAD to happen on my first paying job out out of my garage shop.
