587,224 active members*
3,363 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > 1016 Lube System Fault on Hardinge Cobra 51 w/ Fanuc 21i-T control.
Results 1 to 4 of 4
    Oct 2013
    3
    Halp!
    I have a Hardinge Cobra 51 with a Fanuc 21i-T control. I am currently being plagued with
    "1016 Lube System Fault"
    every time it cycles from the way lube pump/reservoir. I have been using TONNA S2 MX 68 for way lube for the past year, this has only been a problem in the last couple of months.
    Any help/input will be appreciated.
    Sep 2012
    10
    Try taking the lubricator reservoir off and clean the intake screen. I had the same problem and that solved it.
    Oct 2013
    3
    Re: 1016 Lube System Fault on Hardinge Cobra 51 w/ Fanuc 21i-T control.
    Well, I fought this problem on and off for a while, finally called a tech in. Took him about ten minutes to diagnose that my way lube pressure switch had gone bad. Ordered a new one, installed it, and the machine now runs trouble-free.
    Dec 2018
    8
    Quote Originally Posted by aa_campbell View Post
    How did he test the pressure switch, my Cobra 42 is doing the same thing
  1. Hardinge Cobra 65 - Fanuc 21-T - Wont boot up?
    By keindustrial in forum Hardinge Lathes
    Last Post: 03-30-2024, 01:27 PM
  2. hardinge cobra 42 fanuc 21i control
    By waybriks in forum Fanuc
    Last Post: 09-12-2011, 06:41 PM
  3. hardinge conquest 42 VS cobra 42
    By mls in forum Hardinge Lathes
    Last Post: 09-07-2010, 10:42 PM
  4. Hardinge Cobra 51 & Fanuc 21i-T Question
    By CNCBahamas in forum Community Club House
    Last Post: 07-04-2010, 10:37 PM
  5. Parameters on Cobra 42 Hardinge
    By Niall in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2004, 10:38 AM
