587,481 active members*
3,025 visitors online*
    Jul 2010
    0
    10100 Atlas 6" mini-lathe
    I have an Atlas MK2 10100 mini-lathe that I am trying to get into working order. Everything is in great shape, however I am having trouble engaging the back gear drive. I followed all of the instructions to adjust the gear lash, however there is no way to move the gear (X axis direction) to engage the headstock spindle gear. The gears look very good with little wear. Any ideas would be appreciated.
    Nov 2007
    616
    I can't help much, but I did find this page that might be of some help. Don't know if your lathe looks like any of these, but the pics might be helpful. Good luck!
    Page Title
    Engaging backgear on the Model 101 Atlas 6" lathe. At first sight there is no obvious way of releasing the large V pulley from its embrace with the spindle. The secret is the "external locking ring" on the end of the pulley; this is simply pulled outwards to uncouple it from the shaft and the backgear lever then operated as usual to mesh the respective gears.
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
    Jul 2011
    0
    Atlas Model 10100 Back Gear
    Did anyone figure out how to engage the back gear on the atlas model 10100. I have the manual and I've followed the instructions but the back gear doesn't seem to fully engage. Any ideas? This was my grandfather's lathe and was not used (or used very little) prior to his passing. The gears show little or no wear.
  1. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  2. Atlas 12" lathe
    By Jim Ciampi in forum Benchtop Machines
    Last Post: 03-04-2010, 05:56 PM
  3. Atlas Craftsman 6" lathe mod. 109 21270
    By Cropduster in forum Mini Lathe
    Last Post: 10-14-2009, 11:18 PM
  4. Model 101 Atlas 6" lathe
    By rer07 in forum Mini Lathe
    Last Post: 10-14-2009, 11:11 PM
  5. Replies: 5
    Last Post: 01-22-2008, 03:55 PM
