587,238 active members*
3,961 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1010-6A board vs 1010-4A board
Results 1 to 6 of 6
    Oct 2012
    33
    Is there much of a difference? I have a 4020 that has a bad 1010-6A board and another 4020 that needs a ballscrew and that one has a 1010-4A board. Anyone know if they would interchange?
    Thanks!
    Apr 2005
    1194
    Re: 1010-6A board vs 1010-4A board
    Yes
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Oct 2012
    33
    What is the difference between a 1010-4A and a 1010-6A board? I see the reman price between the two is a big difference and if they interchange.....Then why not go with the cheaper board? There must be something that I am missing here....
    Apr 2005
    1194
    Depending on the axis your EEprom software may not work with other cards well in the system. So you cant run a 1400-4 system with -5 or -6 cards and you cannot run the older 1010-4 (pre 92 eeprom softwares) with a 1400-5. The 1400-5 or any 1400 board is the main CPU. You will know it when you make a swap and nothing works.
    Oct 2012
    33
    I currenly use the 1010 series boards. I just didn't know if there was a big change between a 1010-4A and a 1010-6A board. I can get one for $290 reman and the other is $790 reman. if they're the same, then logic would tell me that I could pick up the cheaper reman board, and swap over my EPROMS over correct?
    Apr 2005
    1194
    -4 uses eeproms in u7 and u10 designations on the board. -5 uses a different placing. You cannot mix and match them it will not work. So -4 eeproms can go to -4 boards and -5 to -5.
  1. fanuc mother board problem a16b-1010-210
    By frigoteknika in forum Fanuc
    Last Post: 12-07-2021, 02:45 PM
  2. Replies: 0
    Last Post: 12-27-2016, 06:11 AM
  3. Replies: 2
    Last Post: 06-26-2014, 02:07 PM
  4. fadal 1010-5A logic board for servo control
    By pilot001 in forum Fadal
    Last Post: 03-09-2013, 05:30 PM
  5. wanted a schematic of the board A16B-1010-0150
    By machinationus in forum Fanuc
    Last Post: 10-09-2012, 11:32 AM
